Текущее время: 05 июн 2024, 00:53
madking
Заголовок сообщения: Re: RTX2070 with Micron memory, random blackscreens after changing Добавлено: 21 авг 2020, 13:53 |
Зарегистрирован: 03 ноя 2017, 01:24 Наличности на руках: 4,998.04
Сообщения: 3992 Откуда: Budapest
As I wrote above, change all memory to 8Z 8S under load produces: artifacts, driver ejection, black screen, freezes.
samsung hc-14, when replacing, you need to move the strap, post a photo, we will show which one
madking
Заголовок сообщения: Re: RTX2070 with Micron memory, random blackscreens after changing Добавлено: 21 авг 2020, 19:15 |
Вложение: dscf1785pvk21.jpg
Assassin
Заголовок сообщения: Re: RTX2070 with Micron memory, random blackscreens after changing Добавлено: 17 сен 2020, 21:13 |
Зарегистрирован: 14 май 2020, 20:12 Наличности на руках: 78.21
Сообщения: 61 Откуда: germany
hello again...i have become for free two working D9WCW with date code 8SA77 chips also, so i have replaced for testing the two newer 8ZA77 chips now to 8SA77. But now i have som weired errors - stripes on the screen :-/ the error count is always an other number. I have replaced the C0 chip with another chip - but error still always on C0. sometimes when testing the bank C0 would have no errors, but then A0 or B0 (always x0) I have also reflowed all Memor chips, and GPU - but error still present. is this error picture an indicator of a death GPU? or realy memory chips?
