Заголовок сообщения: Identify components and short on ASUS ROG Strix RTX 2080
Добавлено: 09 мар 2021, 01:42
Зарегистрирован: 02 мар 2021, 03:33 Наличности на руках: 75.06 Сообщения: 19 Откуда: England
I've managed to replace a shorted MOSFET that prevented the PC from powering up with the card installed.
Currently there is 5V on one of the rails (rail at top of photo 3, inductor 4R7 1830), and no voltage to the other power rails on the left side of the card pictured in photo 3.
On the right side of the card, there is 12v to each of the main power rails.
There is one power rail shorted to ground (rail at bottom right of photo 3, inductor 1R0 834 P7K).
I need help identifying the components in the pics below adjacent to the other two rails please before I can proceed.
See photo 3 for location of these - if you can help identify what voltage each power rail should have, I would be grateful.
If you need any other info, please let me know.
Thanks.
ZZZ7ZZZ
Заголовок сообщения: Re: Identify components and short on ASUS ROG Strix RTX 2080 [РЕШЕНО]
Добавлено: 09 мар 2021, 06:21
Зарегистрирован: 26 янв 2012, 10:14 Наличности на руках: 4,903.42 Сообщения: 1894 Откуда: Piter
MSIGamer72, BFDJ - MP8858GQ, BFRJ - MP28168GQ
MSIGamer72
Добавлено: 09 мар 2021, 22:14
That's great thanks, how did you identify them?
ZZZ7ZZZ
Добавлено: 09 мар 2021, 22:56
