Текущее время: 04 июн 2024, 15:32
kolyandex
Заголовок сообщения: Re: gigabyte gtx 1060 6gb не выводит изображение Добавлено: 28 янв 2019, 05:33 |
Зарегистрирован: 11 ноя 2015, 09:19 Наличности на руках: 106.08
Сообщения: 192 Откуда: Новосибирск
Azazehl писал(а): А этот стабилизатор на 5в. как отыскать на плате? Если есть все напряжения, как пишет ТС, то он в порядке.
Pandemonium6
Заголовок сообщения: Re: gigabyte gtx 1060 6gb не выводит изображение Добавлено: 28 окт 2021, 21:00 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
bad fox писал(а): Are the PCI-E feed-through capacitors OK? You know, I got for repair several 1060, 1070 and 1080, Ti and not Ti, mostly Asus brand. All of them have 220n capacitors turned into resistors. Not one, not two but sometimes 20 and more. Instead of 220nF they have resistance between 0 to 50 ohms. Most cards have short circuit (KZ) on the PEX choke. It was a sample from some pallets of consumer returns, as the owner said, but the real history is unknown. External power 12V is OK, PCIe 12V and 3.3V are also good. These cards look like after thunderstorm. He has 380 of them, mostly Asus and Gigabyte and some others but rather rare models. All random picked cards have the same issues, only different signals are dead, sometimes also PEX_RST, REFCLK and others. This is a mystery. Maybe the seller already selected these cards and sold all with dead GPUs? All cards have warranty stickers. 15 of 15 I tested are dead in the same way. What can cause such damage? 12V would not shoot over the 220n capacitor. It was a higher voltage but why only PCIe signals, why not 12V and 3.3V rails? Top lanes without capacitors and bottom with capacitors have also (KZ). Bottom lanes measured before capacitors are dead shorted. Capacitors conduct as ohmic resistors.
