Текущее время: 18 июн 2024, 18:24
 Заголовок сообщения: Zotac RTX 2060 resistor value
СообщениеДобавлено: 24 ноя 2021, 01:18
Hello! can anyone please tell me the value of the resistor in the picture ?
Card: Zotac RTX 2060 6GB Twin Fan
Thanks in advance!!
 Заголовок сообщения: Re: Zotac RTX 2060 resistor value
СообщениеДобавлено: 24 ноя 2021, 02:01
47k
СообщениеДобавлено: 25 ноя 2021, 19:33
aleksros писал(а):
47k
thanks for input, but it was 100k actually. resistor one side goes to 3v3, other to B5 of blade connector (smbclk), measured pullup on B6 and that is 100k
card still not posting.
СообщениеДобавлено: 25 ноя 2021, 22:57
may be. but on my card both resistors is 47k ))
СообщениеДобавлено: 26 ноя 2021, 22:48
This is still big kiloohms could be 10k and it should work. There is probably a different reason it doesn't work. Start from making measurements.
СообщениеДобавлено: 30 ноя 2021, 16:17
I know it should work, I was just saying for reference. no hard feelings :D
I dont have much experience fixing gpus, so I don't really have a clue where to begin. I measured voltages - got 0.8 on phases, and voltage on memory (1.3 ? if my memory is right - Im not home right now)
what I found is that BIOS chip has no activity. xtal is @ 27M. it was late yesterday, so cannot tell you more right now.
being at work right now - watching videos, reading forum!
thanks!
СообщениеДобавлено: 30 ноя 2021, 16:28
I have also 2060 without bios activity and no Idea what I could do. Everything is perfect, resistances and voltages. Maybe a current sensing chip is dead and sets alarm conditions like overcurrent or overvoltage, I will check it again.
СообщениеДобавлено: 07 дек 2021, 16:47
I measured diff pairs, and found A13 pin to be open. Will check traces once more, but otherwise - it's a dead case.
В этой теме нет новых непрочитанных сообщений. Toshiba C55 PT10F UMA MB (İntel) Need Resistor Value
в форуме Toshiba
relax79
05 фев 2016, 11:20
В этой теме нет новых непрочитанных сообщений. Asus X556UJ (Notebook) Resistor value?
CesurISLER
07 дек 2017, 16:40
CesurISLER Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. F15KR_DSC (F15KR_DSC) Resistor value
CesurISLER
13 дек 2019, 23:42
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Predator (g9-593) no ACDET/resistor value?
myth77
17
2977
18 июл 2022, 11:15
mmarc Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Power Color RX 570 8GB help with identifying resistor value.
allas
1328
07 окт 2020, 15:33
allas Перейти к последнему сообщению
Сейчас этот форум просматривают: andrejss, Евгений Владимирович и гости: 22
