Текущее время: 04 июн 2024, 07:57
 Заголовок сообщения: EVGA GTX 970 SC ACX 2.0 black screen after repair
СообщениеДобавлено: 07 июл 2021, 19:59
Hello repair guru team,
I would like to ask you for and help with the GPU repair. I got this GTX 970 EVGA card with damaged vcore VRM. I analysed the card and discovered damaged mosfets and shorted mosfet driver. I removed one VRM phase (X marks) and ordered new mosfets for second part (O mark). Then I discovered broken drop down support voltage 1.05V regulator (marked with O) so I replaced it.
then card staretd to be alive - vcore ok, vram voltage OK and support 1.05 voltage OK. Card is running without 1 VRM phase, because Iam not able to find mosfet driver as replacement. I can see the picture without issue or glitches. After few minutes card goes to black screen, vcore drops to almost 0V and no picture. After the PC restaret, I can see the picture again but lead time for black screen is much shorter. Card is not overheating, its not in the load (just desktop), bios has been flashed with programmer, gpu-z shows no problems. Can you please help me to idnetify what can be the root cause? Is thi an issue with the GPU core balls? Can I somehow find out what caused crash?
Since is already 3rd card which I revived from dead to this statement, I would like to progress little bit more.
Thank you fellas and sorry for English.
 Заголовок сообщения: Re: EVGA GTX 970 SC ACX 2.0 black screen after repair
СообщениеДобавлено: 08 июл 2021, 00:01
you need to restore all VRMs. Without them, this card will not work normally.
СообщениеДобавлено: 08 июл 2021, 14:45
Hello sir,
Thanks for reply, i already had some cards (980 ti asus) without 1 vrm and running absolutely fine for years. Why it is mandatory to fix all vrm stages? Is there any way how to find out why vcore stopped supply?
Thanks
СообщениеДобавлено: 05 май 2022, 13:29
Hi! i got the same scenario, gigabyte gtx 980 , 1 phase blow, another rebuild. in fact 2 phases blown up, and only 1 has recovered. but without driver, card show image on desktop but when the driver install, first blink to detect the card its okey, but after the second blink... black screen and vcore drop almost 100mv. im trying to figure out..
in my case i replace pwm controler, and all doubler/drivers.
В этой теме нет новых непрочитанных сообщений. EVGA gtx 780 sc/acx
nykon
14
3395
11 дек 2018, 23:50
virus.tmn Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1660SUPER ASUS TUF, Black screen but after 2 seconds the image returns on the desktop.
azzed
06 фев 2023, 11:51
Adena Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 14:23
anarasgarli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Motherboard desktop repair _ Ps2 port mainboard repair
в форуме Gigabyte
no2comvn
13 янв 2017, 11:44
no2comvn Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTx 980 all voltages are normal, PWM signal too, but black screen
netcrusher
14 фев 2020, 19:50
Naik Перейти к последнему сообщению
Сейчас этот форум просматривают: Vovan800 и гости: 9
