Текущее время: 04 июн 2024, 11:02
 Заголовок сообщения: Gigabyte RTX 3060 Ti LHR ( GV-N306TVISION OC-8GD Rev.2.0) Hynix to Micron
СообщениеДобавлено: 17 ноя 2022, 16:43
Dear Masters!
I have this Gigabyte 3060 Ti LHR (board number V397 v5.1) that is having memory problems with Hynix (X005) and wanted to replace with Micron (D9WCW) (9E...,9I... not 8xxxx of course).
The problem is the Straps.
From V397 v5.1 Boarview:
Вложение:
Sadly i dont have schematics for V397 only for V390.
In V390 the straps are working as in the picture but with the Hynix it was the opposite of the schematic on the board so not L-H-L but H-L-H and i am confused.
Вложение:
I have already replaced the memory to Micron and set the Straps as the in the V390 Schematic.
Вложение:
Mats test PASS, but i cannot run Mods test 118, 178 or 92 because it gives some error on screen. When the driver installs the screen goes off, and the PC starting to BEEP.
Any advice or someone can tell me what is the good strap configuration for Micron 14Gbps?
UPDATE:
I have made a mistake...
Вложение:
a nasty memory module tricked me...haha :D
I have replaced it, MATS test pass, any mods test gives falcon error after 1 second of test running, so i think the GPU is dead.
Anyway, i think i have understood the "mysterious" strap config for that Hynix...
There's H56G32CS4DX005 - which was in the config H-L-H and there is H56C8H24AIR-S2C which is maybe equals the L-H-L config...
 Заголовок сообщения: Re: Gigabyte RTX 3060 Ti LHR ( GV-N306TVISION OC-8GD Rev.2.0) Hynix to Micron
СообщениеДобавлено: 22 ноя 2022, 14:39
DoktorVGA писал(а):
Dear Masters!
File comment: V397 Boardview Straps positions
File comment: Straps schematic for V390 v6.0
File comment: The card. H-L-L
UPDATE:
Atleast you found one problem of memory :D . About the FALCON Error, I am myself having the same problem with MSI RTX 2070 Super. But not able to find the fault. Might be related to memory or main core. Still not sure. Need experts to answer on it or the ones who have faced such issue and resolved it.
СообщениеДобавлено: 24 ноя 2022, 05:10
Your configuration is ok.
But look at your soldering quality, even on this photo I could tell strap 1 is not installed normally.
Check the gpu-z info about the memory.
D9wcr should work with d9wcw atleast until the driver install and can only be a problem in 1750mhz boost, not 1500.
But your used d9wcw can be dead that way (dont buy used cheaps).
В этой теме нет новых непрочитанных сообщений. RTX 3060ti LHR -> Замена GPU без LHR
yellowfox
23 мар 2022, 00:26
yellowfox Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Rtx 3060 ti palit переделка с hynix на samsung
nikolay26rus
21 сен 2022, 17:18
nikolay26rus Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte RTX 3070 LHR Gaming проблемы на холодную
INVIS
28 окт 2023, 18:47
В этой теме нет новых непрочитанных сообщений. GALAX RTX 3070 converted into 3060TI LHR with ram bank B1 C0 with errors
HeatElectronics
1058
27 июн 2023, 19:37
jeffersonsilva998 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. есть ли разница в номиналах обвязки банок памяти hynix и micron?
intell2000
11 окт 2020, 18:11
uncledim Перейти к последнему сообщению
Сейчас этот форум просматривают: lovaK и гости: 12
