Текущее время: 20 апр 2024, 13:08
 Заголовок сообщения: Gigabyte Rx 570 4GB - Only 12v and 3.3v
СообщениеДобавлено: 26 мар 2020, 20:30
hello everyone, could someone give me a guide to resurrect this card, on the pcb I have 12v (which reach the mosfets) the 5 turns on the regulator outputs and 3.3 on the pins 1 and 8 of the bios chip and the vcc on the IR3567 , also own the 1.8V in Saidan the GS7103, GS7256 bring us have only 12V according to the image.
ps: are 2 GS7256, both with these measures
I believe that the lack of enable is causing the non-operation of the circuits, someone would know to inform where this enable is generated so that I start my search.
]Изображение
 Заголовок сообщения: Re: Gigabyte Rx 570 4GB - Only 12v and 3.3v
СообщениеДобавлено: 28 мар 2020, 03:38
when replacing the apw8713 the voltages returned to the vrm and the memories however do not have the 0.9 volts in this phase:
from what I understand this switching is done by a GS7256, but I only have 12v on pins 1 and 5, would anyone know to tell me where the enable for this pwm comes from?
RL500: 112.7ohms
СообщениеДобавлено: 28 мар 2020, 15:06
enable - 7 pin of GS7256, chek connected to NPN trasis around... (may be Q1604?)
- Йцукен?
- Фывапрол!!
 Заголовок сообщения: Re: Gigabyte Rx 570 4GB - Only 12v and 3.3v  [РЕШЕНО]
СообщениеДобавлено: 28 мар 2020, 20:19
this, seriously enable pin 7, but in the multimeter there was no voltage there, thanks for the answer, for example, to see the image on a pcb there was no gpu installed on a 110 ohm coil resistance, to resell a gpu the resistance dropped to 19, and the Gs returned to work, apparently he was in protection, problem solved I will close the topic.
В этой теме нет новых непрочитанных сообщений. (ONLY POWERS ON X470 ASROCK MASTER SLI MOTHERBOARD) RX 570 4GB GIGABYTE REV1.1
azzed
09 окт 2022, 23:13
azzed Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. error when increasing memory of rx 570 from 4gb to 8gb - ошибка при увеличении памяти rx 570 с 4гб до 8гб
TheMArcos
11
2664
12 ноя 2021, 12:51
agsmt Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. переделка блока питания ATX в блок для fujitsu 12v only
в форуме Ремонт ИБП | UPS repair
romanck
30 май 2019, 15:53
romanck Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus GTX 1060 6gb Strix only 12v
TheMArcos
21 мар 2020, 22:32
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Palit GTX970, only draw round 600mA @ 12V, no picture
Assassin
26 июл 2022, 14:44
SimbA Перейти к последнему сообщению
Сейчас этот форум просматривают: Elektrik503, maxlabt, YuriyB и гости: 13
