replacement of rx80 gpu in rx 570 pcb https://vlab.su/viewtopic.php?f=48&t=101137 |
TheMArcos [ 29 мар 2020, 03:42 ] | |
Заголовок сообщения: | replacement of rx80 gpu in rx 570 pcb |
Gentlemen, I installed a rx580 gpu on a rx570 pcb, both gigabyte, the pcb seems to be the same, however when trying to re-record the bios through amdvbflash I have the following error: incorrect subsystem id. someone would know what to do to be able to re-record the biosa, because although the card is functional even for the game, gpu-z is unable to read the sensors. |
Ancona228 [ 29 мар 2020, 03:45 ] | |
Заголовок сообщения: | Re: replacement of rx80 gpu in rx 570 pcb |
if crystals are same, problem may be in pcb? |
galkinvv [ 29 мар 2020, 04:40 ] | |
To allow overriding subsystem Id just use non-gui version of atiflash.exe and pass "-fs" argument. (but check to use 570 vbios for compatible PCB, preferably with the same number of power phases as your pcb) |
TheMArcos [ 07 апр 2020, 05:35 ] | |
guys, follow the error I'm having when trying to update the bios, I used the unlockrom command, then I tried to re-record with -f and -fs, but this error still appears. |
galkinvv [ 07 апр 2020, 14:20 ] | |
You do NOT need unlockrom command. But you need modern atiflash version that spports rx470/rx480 cards https://www.techpowerup.com/download/ati-atiflash/ It DO contain cmd-line version too. |
TheMArcos [ 08 апр 2020, 01:18 ] | |
galkinvv писал(а): Mas você precisa da versão moderna do atiflash que suporta cartões rx470 / rx480 https://www.techpowerup.com/download/ati-atiflash/ Ele também contém a versão da linha cmd. so ... I can't execute the commands in this 2.93 version of atiwinflash, do I have to download UEFI SHELL VERSON? |
galkinvv [ 08 апр 2020, 01:53 ] | |
TheMArcos писал(а): so ... I can't execute the commands in this 2.93 version of atiwinflash, do I have to download UEFI SHELL VERSON? No, UEFI SHELL VERSION is not needed. Use amdvbflash.exe from 2.93 windows version. Does 2.93 report any error? Note: you should reboot windows to change atiflash version (different driver versions). Or select "Show more versions" and use atiflash_277.zip |
