XFX R7 370 checkered artifacts https://vlab.su/viewtopic.php?f=48&t=101508 |
TheMArcos [ 10 апр 2020, 01:34 ] | |
Заголовок сообщения: | XFX R7 370 checkered artifacts |
hello Masters, in my little experience I had never seen this type of artifacts, the plate does not crash, does not lose video, just stay with these types of artifacts (image), is it a case of damaged bga or memory? has anyone seen? and have any guidance you can give me? |
GA-8i915 [ 10 апр 2020, 11:21 ] | |
Заголовок сообщения: | Re: XFX R7 370 checkered artifacts |
Hi! It's first time characteristic for memory, second time for gpu. You can test mats http://vlab.su/viewtopic.php?f=48&t=96805&hilit=%2Amats%2A |
meohaimat2021 [ 10 апр 2020, 12:18 ] | |
mats are not tested with AMD |
GA-8i915 [ 10 апр 2020, 12:56 ] | |
meohaimat2021 писал(а): mats are not tested with AMD if amd, then try compare heat video memory, clip video memory and gpu, off vtt for video every separately chips. But the fastest heat test for gpu. |
TheMArcos [ 11 апр 2020, 19:05 ] | |
hello, I decided to make a reflow on the gpu and on the memories and the artifacts on the windows screen are gone, in heaven benchamark I also didn't notice any artifacts, but when opening Msi Kombustor it still detects several artifacts, I believe it really is a case of reballing. Posted after 3 hours 51 minute 30 seconds: GA-8i915 писал(а): if amd, then try compare heat video memory, clip video memory and gpu, off vtt for video every separately chips. But the fastest heat test for gpu. unfortunately I don't have a thermal imager, I left heaven running for a few hours and the card was apparently working normally, so I went to play The Division 2, and after about 15 minutes the artifacts came back. if i put a heatsink just noble to the GPU, can i notice any difference in temperature in the memory modules? |
GA-8i915 [ 17 апр 2020, 22:32 ] | |
TheMArcos писал(а): if i put a heatsink just noble to the GPU, can i notice any difference in temperature in the memory modules? For this install another heatsink. |
