Текущее время: 11 май 2024, 12:56
galkinvv
Заголовок сообщения: Re: bubble on chip Добавлено: 14 апр 2020, 19:07 |
Зарегистрирован: 09 янв 2017, 12:18 Наличности на руках: 250.39
Сообщения: 651 Откуда: Зеленоград
aleksros писал(а): but, we have hope!!! try change memory banks u2600, u2700. You mean replacing then with new/from-another-card memory banks, yes? (and NOT swapping them?) Resolution on the photo seems to be 1024x768, since for 1024x768 every screen line occupies 1024*4=4096 bytes and polaris amd memory has a mapping with period of 0x800=2048 bytes, and we can visually see that every screen line contains exatly two regions with a problem (like 0x600-0x7FF and 0xE00-0xFFF). The visually damaged region size is 0x200, which corresponds to a pair of modules on amd polaris (consequtive 0x100 is a single module). So two modules looks problematic, not one, so swapping looks questionable...
aleksros
Заголовок сообщения: Re: bubble on chip Добавлено: 14 апр 2020, 22:01 |
Зарегистрирован: 26 ноя 2011, 01:09 Наличности на руках: 2,600.26
Сообщения: 4473 Откуда: Киев
galkinvv писал(а): You mean replacing then with new/from-another-card memory banks, yes? ( yes, replace with new ones. I never change places, only for new ones (sometimes I take with donors)
TheMArcos
Заголовок сообщения: Re: bubble on chip Добавлено: 15 апр 2020, 20:45 |
Зарегистрирован: 18 мар 2020, 04:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
КомпБит писал(а): Posted: Yesterday, 09:45 Thermal shock on the printed circuit Board of the GPU itself (bloated bubbles ) GPU 999% for replacement. Who warmed it up or sealed it overheated with a high temperature ! I was the one who changed the gpu and I'm sure this bubble was not there, this chip was from a rx570 used in mining (I don't know how far it influences) but the board worked for 45 days normally (it's my property), until it presented rtefatos, when dismounting I noticed the bubble formed. aleksros писал(а): it's very bad... but, we have hope!!! try change memory banks u2600, u2700. It is good to know that in this possibility, I will make the replacement, even if only for study reasons! I'll bring the result here!
TheMArcos
Заголовок сообщения: Re: bubble on chip Добавлено: 21 апр 2020, 04:13 |
hi guys, I believe it is the end of the case, I got a gpu from another Rx80 that had a lot of damage to the PCB, and the chip so far is working well, without artifacts until then, I will be testing the artifact all week. Thank you all for your help.
