Текущее время: 28 апр 2024, 21:49
sshana
Заголовок сообщения: Re: XFX RX 480 FAULTY Добавлено: 01 май 2020, 22:53 |
Зарегистрирован: 11 мар 2020, 06:57 Наличности на руках: 29.04
Сообщения: 20 Откуда: Venezuela
Gpu core works, already tested, also, sometimes if you install drivers while you are in Windows it works (but still no fan spin, even if it reach 89°), but if you restart the computer with drivers installed, it wont work, blue screen will appear (Driver Threat Stuck ir something like that)
It's not Driver related, nor BIOS, there's something on the board that is causing the issue but i dont know where to start
sshana
Заголовок сообщения: Re: XFX RX 480 FAULTY Добавлено: 03 май 2020, 23:58 |
I'm a bit confused, what do i need to measure? This is the card: Вложение: IMG_20200503_155232.jpg
aleksros
Заголовок сообщения: Re: XFX RX 480 FAULTY Добавлено: 04 май 2020, 11:29 |
Зарегистрирован: 26 ноя 2011, 01:09 Наличности на руках: 2,610.26
Сообщения: 4473 Откуда: Киев
sshana писал(а): I wish the problem was that simple. and you should try to get started. even the photo shows that there is a stone.
sshana
Заголовок сообщения: Re: XFX RX 480 FAULTY Добавлено: 04 май 2020, 23:47 |
aleksros писал(а): and you should try to get started. even the photo shows that there is a stone. Dude, that's a working XFX you seeing here (the upper one), just dissasembly it for maintenance and took a photo, 55º on max load (100% fanspeed), i've already tried every simple thing with the non-working cards. Thanks anyway for your attention,.
