https://vlab.su/
GTX770 - where is FAN PWM coming from?
https://vlab.su/viewtopic.php?f=48&t=105496
Страница 1 из 1
Assassin [ 02 авг 2020, 22:09 ]
Заголовок сообщения:  GTX770 - where is FAN PWM coming from?
Hello there...i have a GTX770 4GB where FANs not spinning, because PWM Pin is not supply anything. On Startup fans shortly spin up (0.5sec) and then stand still. set fan PWM to 100% with MSI afterburner shows 100% in GPU-z but still no PWM on pin. Also testet other Bios.
i have tries to track the trace from PWM 4-Pin fan connector, but can absolutly nothing find on PCB :-/ so i think the PWM signal comes straight from GPU...but is it possible?
GPU is working fine, no graphic issues, works also hours on benchmarks...all fine, except the Fan controlling
Conqueror [ 02 авг 2020, 22:37 ]
Заголовок сообщения:  Re: GTX770 - where is FAN PWM coming from?
Hello! What is about the main buck controller at your board? Doues it have a PWM Controller feature?
http://www.phpbb.com/
