Msi gtx 1080 Need driver identification https://vlab.su/viewtopic.php?f=48&t=106523 |
potas [ 03 сен 2020, 20:26 ] | |
Заголовок сообщения: | Msi gtx 1080 Need driver identification |
Hello. One of a drivers is broken. Please help me with the identification that i could order replacement. Markings are DU F663. Thank you |
wraper [ 03 сен 2020, 21:28 ] | |
Заголовок сообщения: | Re: Msi gtx 1080 Need driver identification |
I don't know what it is but you could check if pinout matches with NCP81062 which you probably could use as replacement. What is VRM controller model? |
aleksros [ 03 сен 2020, 23:03 ] | |
up1959p - try it )) |
potas [ 08 окт 2020, 19:19 ] | |
Заголовок сообщения: | Re: Msi gtx 1080 Need driver identification [РЕШЕНО] |
up1959p works, Thank you guys for advice. |
