Card used for miningi , motherboard burned. Resistance of all lines normal. The card starts normally, all voltage is present. It is not detected. I checked all lines pcie no deviation. There is a ripple on quartz. No movement on pins 2 and 5 bios. Voltage on pin 1 1.8V. Dead core. ??
galkinvv
Заголовок сообщения: Re: Asus GTX 1070 dual no bios reading .
