Aртефакты на RTX 2070 & 2080 Ti после обмена https://vlab.su/viewtopic.php?f=48&t=109621 |
cxav [ 30 ноя 2020, 01:19 ] | |
Заголовок сообщения: | Aртефакты на RTX 2070 & 2080 Ti после обмена |
ENGLISH version : Hi, sorry to write in english in a russian forum, I couldn't find another forum with experienced repairmen. I have 3x RTX 2070 (Micron GDDR6) and 2x RTX 2080 Ti (Samsung GDDR6), using Nvidia MATS 400.184 "mats -e 50|less" I managed to find which GDDR6 chip gave me write error on all of their bits, I decided to use one of the 2070 and one of the 2080 Ti for parts. At first it was heavy artifacts and/or black screen when drivers loaded for the 2070 and only artifacting at idle/light load for the 2080 Ti So I used 2 of the "error free" (no write error) GDDR6 from the spare 2070 to replace the not working GDDR6 of the other 2 RTX 2070, same for the RTX 2080 Ti, I did not mixed GDDR6 brand. The Micron are "8S" and "8U", and I don't know how to read date code on Samsung, I know they are likely to die soon but I wanted to see if everything else was working fine before buying ~300€ of GDDR6 for all of them... NOW, I have 2 RTX 2070 and 1 RTX 2080 Ti with no error on Nvidia MATS but both RTX 2070 black screen after drivers is loaded (no artefact at all) and the RTX 2080 Ti is artifacting at idle/light load like space invader (no change here). My question are : - Why the card are not working properly while it's ok with MATS ? - Dead core ? - Dead memory ? Thanks for your help ------------------------------------ RUSSIAN TRANSLATION : Привет, извините, что пишу на английском на русском форуме, я не нашел другого форума с опытными ремонтниками. У меня есть 3x RTX 2070 (Micron GDDR6) и 2x RTX 2080 Ti (Samsung GDDR6), используя Nvidia MATS 400.184 «mats -e 50 | less». Мне удалось найти, какой чип GDDR6 дал мне ошибку записи во всех их битах, я решил использовать один из 2070 и один из 2080 Ti для запчастей. Сначала это были тяжелые артефакты и / или черный экран при загрузке драйверов для 2070 и артефакты только при холостом ходу / небольшой нагрузке для 2080 Ti. Итак, я использовал 2 «безошибочных» (без ошибок записи) GDDR6 из запасного 2070, чтобы заменить неработающие GDDR6 других 2 RTX 2070, то же самое для RTX 2080 Ti, я не смешивал марку GDDR6. Micron - это «8S» и «8U», и я не знаю, как читать код даты на Samsung, я знаю, что они, скорее всего, скоро умрут, но я хотел проверить, все ли работает нормально, прежде чем покупать ~ 300 евро GDDR6 для всех ... СЕЙЧАС у меня есть 2 RTX 2070 и 1 RTX 2080 Ti без ошибок на Nvidia MATS, но оба RTX 2070 с черным экраном после загрузки драйверов (вообще без артефактов), а RTX 2080 Ti артефактует при простоях / небольшой нагрузке, как космический захватчик ( без изменений). Мой вопрос: - Почему карта не работает, а с MATS все нормально? - Мертвое ядро? - Мертвая память? Спасибо за вашу помощь |
TheMArcos [ 30 ноя 2020, 03:12 ] | |
Заголовок сообщения: | Re: Aртефакты на RTX 2070 & 2080 Ti после обмена |
can you post photos with a good definition of the front and back of the card? sometimes this problem of dark screen after the drivers may be connected to the gpu memory controller or the lack of resistors in the polirazation circuits (I don't know if that would be the correct term for that) of the memory modules. I have also had problems of this type where an attempt of bios mode was involved, by the owner of the card можно ли размещать фотографии с хорошей четкостью лицевой и оборотной сторон карты? иногда это проблема темного экрана после подключения драйверов к контроллеру памяти графического процессора или отсутствие резисторов в цепях полиразации (я не знаю, будет ли это правильный термин для этого) модулей памяти. У меня тоже были проблемы такого типа при попытке включения режима биоса владельцем карты |
madking [ 30 ноя 2020, 04:03 ] | |
Начнем с того что надо дать производителя, каждый располагает по своему ГПУ Ну и раз вы сделали тему по всем картам, вот вам ответ, а там уже сами разбирайтесь, кто с кем и куда. Кроме как менять память, надо еще и прозванивать пятаки в сторону ГПУ, 80% просто отвал углов ГПУ, это ко всем картам относится что вы упомянули. Перекатывайте ГПУ и память вот и будет вам счастье. Что касается "8S" то в мусорку. |
TheMArcos [ 30 ноя 2020, 05:46 ] | |
madking писал(а): Что касается "8S" то в мусорку. «8S» имеют свойство выходить из строя? |
madking [ 30 ноя 2020, 06:39 ] | |
TheMArcos писал(а): «8S» имеют свойство выходить из строя? на моей практике, пока только с ними встречался, в мусорке оказываются "8R", "8S", "8T". в матсе пишет "pass", при запуске одновременно GPU-Z rendering (находится при нажатии на "?") + furmark, выдает артефакты, BSoD, "space invaders" |
uncledim [ 30 ноя 2020, 07:58 ] | |
madking писал(а): в мусорке оказываются "8R", "8S", "8T" Есть у кого-нибудь информация, а что собственно происходит с этой памятью "с магниевыми частицами"? Может ее [превентивно] на свинец перекатать и проблема [не возникнет]уйдет? Или проблема глубже? Ну например как в свое время с винчестерами фуджитсу 20-гиговыми, серии MPG-, если память не изменяет. Тогда между ногами микросхемы прорастали коротыши, из-за косячной корпусировки. И то, умельцы решение нашли (нетривиальное, химия требовалась не бытовая, но всяко без замены)... |
clockerkz [ 30 ноя 2020, 08:59 ] | |
uncledim писал(а): Есть у кого-нибудь информация, а что собственно происходит с этой памятью с ней происходит брак, это вроде даже сам микрон признал. Катать бесполезно, может заработать на день-два месяц-два и потом деградирует окончательно, монтаж и т.п. не причём. А проблемы с монтажом и контактной площадкой встречается онли у самсунг. |
uncledim [ 30 ноя 2020, 09:34 ] | |
clockerkz писал(а): это вроде даже сам микрон признал гуглил. бестолку. хотелось бы ссылку) вот про "загрязненный" tsmc, на который кивают на форумах nvidia в темах про отваливающиеся rtx-ы - ссылок навалом, но опять же за уши притянуто https://www.anandtech.com/show/13975/ts ... st-revenue |
cxav [ 30 ноя 2020, 23:02 ] | |
ENGLISH : Sorry for the unclear/incomplete information, - RTX 2070 Gigabyte : When I got it, it was artifacting in BIOS and MATS, FBIOB0 was faulty, I replaced it with a "no error" chip from another 2070. Some capacitor were missing in the back of the card (behind GDDR6 chip, because of not carefull previous owner), I replaced them with capacitor from behind GDDR6 chip of an another 2070 (that should be the same value). Also a "2N7002K" was broken (because of not carefull previous owner), I replaced it with another one (from a 980Ti). Now there is no error on MATS but when the drivers are loaded, the card black screen or BSOD (nvlddmkm.sys). I'm gonna try another vbios. - RTX 2070 HP : I replaced one GDDR6, worked for a around 30 minutes then I rebooter and another one was faulty, I didn't checked Raytracing, but the core should be fine ? I now need 8 new chip for this card. - RTX 2080 Ti MSI Trio : When I got it, it was artifacting in Windows with drivers loaded (black rectangle like in the GPU-Z screenshot), no tested in game, FBIOB0 was faulty, I replaced it with a chip from another 2080 Ti (which have one of the mem chip shorted, with coil removed mosfet are not shorted to ground or 12v so the GDDR6 chip should be fine, except for the shorted one). Now there is no error on MATS but artifacts are still present and the card is unable to run "high" load, GPU-Z 2D and Catherine Classic ("light" 3D game) are working but artifactings : Before replacing the GDDR6 chip (it's still doing it now) : https://imgur.com/a/N1yPISX Catherine Classic after the GDDR6 swap and no error in MATS : https://imgur.com/a/HhHr2EK Picture of RTX 2070 and 2080 Ti : https://drive.google.com/drive/folders/ ... sp=sharing 1. Are Samsung GDDR6 "safer" than Micron GDDR6 ? 2. Is it possible to replace Micron GDDR6 by Samsung GDDR6 ? 3. Do I need to change a strap resistor ? 4. K4Z80325BC-HC16 are only clock higher than K4Z80325BC-HC14 ? (for the price difference I think I should get the HC16 over HC14) 5. I was thinking about ordering on Aliexpress, is it safe ? edit : so I should check resistance (ohm) between each GDDR6 pads (when it's removed) and ground to know if there is a faulty ball behind the core ? Thanks for your help ------------------------------------ РУССКИЙ : Извините за неясную / неполную информацию, - RTX 2070 Gigabyte: Когда я получил его, он имел артефакты в BIOS и MATS, FBIOB0 был неисправен, я заменил его на чип «без ошибок» от другого 2070. Некоторый конденсатор отсутствовал на задней стороне карты (за чипом GDDR6 (из-за невнимательности предыдущего владельца), я заменил их конденсатором из-за чипа GDDR6 другого 2070 (это должно быть такое же значение). Также был сломан «2N7002K» (из-за невнимательности предыдущего владельца), я заменил его на другой (от 980Ti). Теперь на MATS нет ошибки, но при загрузке драйверов черный экран карты или BSOD (nvlddmkm.sys). Я попробую другой vbios. - RTX 2070 HP: я заменил один GDDR6, проработал около 30 минут, затем перезагрузил, и еще один был неисправен, я не проверял трассировку лучей, но ядро должно быть в порядке? Теперь мне нужно 8 новых чипов для этой карты. - RTX 2080 Ti MSI Trio: когда я получил его, он артефактовал в Windows с загруженными драйверами (черный прямоугольник, как на скриншоте GPU-Z), не тестировался в игре, FBIOB0 был неисправен, я заменил его на чип от другого 2080 года Ti (у которых закорочена одна из микросхем памяти, с удаленной катушкой, mosfet не замкнут на землю или на 12 В, поэтому с микросхемой GDDR6 все должно быть в порядке, за исключением закороченной). Теперь на MATS нет ошибок, но артефакты все еще присутствуют, и карта не может работать с «высокой» нагрузкой, GPU-Z 2D и Catherine Classic («легкая» 3D-игра) работают, но артефакты: Перед заменой чипа GDDR6 (он все еще это делает): https://imgur.com/a/N1yPISX Catherine Classic после подкачки GDDR6 и без ошибки в MATS: https://imgur.com/a/HhHr2EK Изображение RTX 2070 и 2080 Ti: https://drive.google.com/drive/folders/ ... sp=sharing 1. Samsung GDDR6 "безопаснее" Micron GDDR6? 2. Возможна ли замена Micron GDDR6 на Samsung GDDR6? Нужно ли менять ремешок? 3. K4Z80325BC-HC16 только часы выше, чем K4Z80325BC-HC14? (из-за разницы в цене, я думаю, мне стоит купить HC16 вместо HC14) 4. Подумывал заказать на Алиэкспресс, это безопасно? изменить: поэтому я должен проверить сопротивление (Ом) между каждой контактной площадкой GDDR6 (когда она снята) и землей, чтобы узнать, есть ли неисправный шар за сердечником? Спасибо за вашу помощь |
TheMArcos [ 01 дек 2020, 01:50 ] | |
cxav писал(а): RTX 2070 Gigabyte : When I got it, it was artifacting in BIOS and MATS, FBIOB0 was faulty, I replaced it with a "no error" chip from another 2070. Some capacitor were missing in the back of the card (behind GDDR6 chip, because of not carefull previous owner), I replaced them with capacitor from behind GDDR6 chip of an another 2070 (that should be the same value). Also a "2N7002K" was broken (because of not carefull previous owner), I replaced it with another one (from a 980Ti). Now there is no error on MATS but when the drivers are loaded, the card black screen or BSOD (nvlddmkm.sys). I'm gonna try another vbios. taking into account its history, I still believe that the problem has to do with the lack of any resistor, would it be possible to post photos? |
cxav [ 01 дек 2020, 02:17 ] | |
Photos are in the google drive link "Picture of RTX 2070 and 2080 Ti " :) |
cxav [ 02 дек 2020, 02:59 ] | |
any idea for the 2080 Ti ? it's memory or core related ? есть идеи для 2080 Ti? это связано с памятью или ядром? |
reshka90 [ 05 дек 2020, 05:28 ] | |
Если есть нижний подогрев на 100 градусах пусть полежит плата,если заработает,то гпу под замену |
