Am i right that second chip marked as "A" on photo is broken? i changed that chip and chip "B" and still i got same error and artifacts, I heated gpu and reflow it and still the same issue. What im doing wrong?
yes, you are right. may be check for broken trace?
xxkachellxx
Заголовок сообщения: Re: GTX 780TI artifacts
Добавлено: 04 фев 2021, 20:19
Зарегистрирован: 21 мар 2020, 14:42 Наличности на руках: 270.04 Сообщения: 85 Откуда: Poland
I will check as soon as I will be at home, but if traces are fine so what could be wrong? Memory controller in gpu? I have good gpu from 780, could it be swapped only with change bios?
Сейчас этот форум просматривают: alexzel и гости: 37
