1070TI согнутый GPU https://vlab.su/viewtopic.php?f=48&t=112012 |
hashwood [ 08 фев 2021, 16:51 ] | |
Заголовок сообщения: | 1070TI согнутый GPU |
Any advices please for a 1070TI chip that has it's marking bent upwards. How can it be repaired? i tried to reball and reflow it again but no luck, it looks the margins are not soldered ok. Is it a technique for this ? it looks like this: |
madking [ 08 фев 2021, 17:12 ] | |
Заголовок сообщения: | Re: 1070TI согнутый GPU |
какие шары используете? |
hashwood [ 08 фев 2021, 17:20 ] | |
0.45 шары Posted after 1 hour 6 minutes 4 seconds: I added 10 grams on chip, reflow, and now it looks OK. But still no image, no MATS. Maybe the chip is bad internally, but it gets hot normally... |
Андрей Сенин [ 10 фев 2021, 12:31 ] | |
Чип точно качался при пайке? По фото как будто не припаян. |
EYES [ 11 фев 2021, 03:11 ] | |
Try to heat it on one side so it bends to the opposite direction and becomes flat again? |
uncledim [ 11 фев 2021, 21:43 ] | |
я бы попробовал после реболлинга перед посадкой "шлифануть" чип на ровной неполированной железке, чтоб центральные шары малость сточились |
hashwood [ 14 фев 2021, 16:29 ] | |
thanks for your answers first set of pictures are from reballing the bent gpu. on the second set of pictures, I added a 10 grams coin on the chip, and then reflow (bga reflow). from the pictures it looks ok, but it still not working. don't know why.... maybe it's a bad connection somewhere, maybe the chip has internal cracks. what makes me sad is that when in stalled on computer it heats up instantly like a normal chip does. but that's all, no image, no detection in MATS, not showing in windows device manager. I now have another 1070Ti with shorted memory mosfet, that damaged the PCB. I plan to take the GPU and reball on the card with bent GPU. The GPU from shorted MOSFTET card measures 20ohm, on memory coil. What do you think? is the GPU shorted? or Is a 1070TI with 20ohm on memory coil OK? google translate: спасибо за ваши ответы первый набор картинок от реболлинга погнутого гпу. на втором наборе изображений я добавил монету 10 грамм на чип, а затем оплавил (bga reflow). Судя по фотографиям, он выглядит нормально, но все равно не работает. не знаю почему .... может где то плохая связь, может в чипе внутренние трещины. что меня огорчает, так это то, что когда он застрял на компьютере, он мгновенно нагревается, как обычный чип. но это все, ни изображения, ни обнаружения в MATS, ни отображения в диспетчере устройств Windows. Теперь у меня есть еще один 1070Ti с закороченным МОП-транзистором памяти, который повредил печатную плату. Планирую взять GPU и реболлинг на карту с загнутым GPU. Графический процессор от закороченной карты MOSFTET измеряет 20 Ом на катушке памяти. Что вы думаете? закорочен графический процессор? или 1070TI с 20 Ом на катушке памяти в порядке? |
hashwood [ 22 мар 2021, 00:26 ] | |
Я отказался от 1070, но теперь у меня 1080 с такими же проблемами, как если бы. Подняты два угла. после реболла: относительно разъема PCI: url for an image Глядя вниз по памяти: Я попробовал переформатировать, добавив две монеты для веса, и это выглядит так сверху, по воспоминаниям: upload gambar Монитор запускается через 20 секунд, думаю, с большой частью памяти не общается. MATS делает report.txt размером 0 байт. В остальном все замеры хорошие, как у исправного процессора. Я думаю снова попробовать реболлинг и немного нажать на нижний и верхний угол, чтобы сформировать контакты вверху, как на первом рисунке. Другие предложения, пожалуйста. |
Vasyasneg [ 22 мар 2021, 18:53 ] | |
Если чип "подымает крылья" - то это перегрев, либо слишком быстрый разогрев по низу. За какое время плата разогревается от +25 градусов до момента расплавления шаров? |
hashwood [ 24 мар 2021, 23:32 ] | |
Спасибо за ответ. Я использую bga-машину. С той же программой для всех лиц. Конечно, со свинцом или без него. Вот так и купил пластину. раньше он бывал в другой службе. реболл преуспел точно так же. |
