Текущее время: 19 май 2024, 11:59
pEEp
Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming Добавлено: 18 фев 2021, 01:49 |
Зарегистрирован: 25 сен 2018, 20:41 Наличности на руках: 709.36
Сообщения: 1114 Откуда: Севастополь
xxkachellxx писал(а): Tried lower clocks of memory and gpu to minimum in afterburner - nothing happend. 1) GPU clock + powerlimit on MIN. 2) PWMs on GPU fases?
galkinvv
Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming Добавлено: 18 фев 2021, 12:16 |
Зарегистрирован: 09 янв 2017, 12:18 Наличности на руках: 250.39
Сообщения: 651 Откуда: Зеленоград
Connecting osciloscope to phase is the way. All measurements should be taken at the max load that didn't cause black screen (-75% I think). Don't measure on light desktop-only load - for such case it can turn in power-saving mode that looks different. There are two ways to measure: 1. Standard phase measurement: oscilloscope ground to the card ground, probe to phase before coil; check that all phases oscillating pictures are similar. 2. Extended/non-standard phase measurement (do with caution and thinking on your own risk! be sure that nothing extra will touch oscilloscope ground): oscilloscope ground to the card 12V, probe to phase before coil; you should check that while high gate is open - all phases stabilizes near 12V in similar way. See my example pictures with different phase behaviour (one picture is for a non-working-fine phase) at viewtopic.php?p=806536#p806536I performed the measurement 2 on some more cards - and found that nearly all of them has picture similar to "bad" on the link above on all phases, and this is fine. So it's important to see "is there a difference between phases", not "does all phases similar to good or similar to bad".
pEEp
Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming Добавлено: 20 фев 2021, 01:29 |
xxkachellxx писал(а): Is GPU dead? xxkachellxx писал(а): when i set clocks to normal and TDP-75% still fine Mem - 100%, GPU - 100%, PL - 75..80%. Furmark. Results? Marking MOSFETs (up + down) ?
pEEp
Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming Добавлено: 20 фев 2021, 04:05 |
xxkachellxx писал(а): On mem 100% (normal clocks) gpu 100% (normal clocks) and pl +75% (175%) in furmark black screen after 15sec. But if mem=75%, GPU=100%, PL=75% all is Ok? xxkachellxx писал(а): look like some capacitor or something like that? ...or tempetarute?
pEEp
Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming Добавлено: 20 фев 2021, 15:30 |
xxkachellxx писал(а): Temperature of gpu before black screen was about 55/60c degree. not GPU, but MOSFETs
pEEp
Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming Добавлено: 21 фев 2021, 01:13 |
xxkachellxx писал(а): So how to check mosfet temperatures? Thermal imager, thermocouple, pyrometer... finger. For your MOSFETs - u better change them on analogs, but with Id more than 32A.
