Текущее время: 19 май 2024, 11:59
 Заголовок сообщения: Strange black screens RX 560 2GB Gigabyte Gaming
СообщениеДобавлено: 12 фев 2021, 00:13
Hello friend, as i wrote in title i have rx560 which i bought as damaged with knife (little scratch on pci lines). I Connected everything and video show up, but while i was running furmark i had black screen, tried to reboot but mobo beeps as card is not connected. I turn off and on psu and GPU worked again, but the same issue, in furmark or etc i get black screen. After that i though it can be windows 7 problems so i installed fresh windows 10 and while installing it the fans of gpu ramped up to 100% and stuck that all the time. MSI afterburner and other apps cannot change fan speed (138%speed lol) but the gpu test after that was fine and no black screens (i'm not perfectly sure because test was about 10minutes cause of that angry loud of fans). I decided to change fans from other fans and control of fans started working again, i can change speed of fans but i have the same issue that earlier with black screens :|
What it could be guys?
I tried reflow too all the card - nothing happend, Tried lower clocks of memory and gpu to minimum in afterburner - nothing happend.
Thank you guys!
 Заголовок сообщения: Re: Strange black screens RX 560 2GB Gigabyte Gaming
СообщениеДобавлено: 12 фев 2021, 13:28
I forgot, black screens in furmark are not instant, it works about 2 minutes before black screens. Gpu temp before is about 55degress celcius. After black screen when I left it for a while it cools down so gpu is not working when black screen.
СообщениеДобавлено: 18 фев 2021, 00:07
I tried on other motherboard, and got the same black screens in liad, what cause that problems guys? I don't have any idea :(
СообщениеДобавлено: 18 фев 2021, 01:49
1) GPU clock + powerlimit on MIN.
2) PWMs on GPU fases?
СообщениеДобавлено: 18 фев 2021, 02:49
When clock, memory and power set to -75%TDP is working fine, when i set clocks to normal and TDP-75% still fine, but when i set TDP to -65% black screen. To measure PWM on mosfets should i disconnect every phase and measure output of the mosfets or only should i connect osciloscope to phase? I didnt do that earlier.
СообщениеДобавлено: 18 фев 2021, 12:16
Connecting osciloscope to phase is the way.
All measurements should be taken at the max load that didn't cause black screen (-75% I think). Don't measure on light desktop-only load - for such case it can turn in power-saving mode that looks different.
There are two ways to measure:
1. Standard phase measurement: oscilloscope ground to the card ground, probe to phase before coil; check that all phases oscillating pictures are similar.
2. Extended/non-standard phase measurement (do with caution and thinking on your own risk! be sure that nothing extra will touch oscilloscope ground): oscilloscope ground to the card 12V, probe to phase before coil; you should check that while high gate is open - all phases stabilizes near 12V in similar way.
See my example pictures with different phase behaviour (one picture is for a non-working-fine phase) at viewtopic.php?p=806536#p806536
I performed the measurement 2 on some more cards - and found that nearly all of them has picture similar to "bad" on the link above on all phases, and this is fine.
So it's important to see "is there a difference between phases", not "does all phases similar to good or similar to bad".
СообщениеДобавлено: 19 фев 2021, 00:45
Ok i measured and all phases looking good as in your photo (i attached that) and i discovered something, even on everything (clock gpu, mem, power) set to minimum in furmark i got still black screens but msi kombustor seems to work.
---------- Добавлено спустя 6 минут 38 секунд: ----------
All phases seems to be the same as others, i attach all phases.
---------- Добавлено спустя 3 минуты 27 секунд: ----------
It was tested your second method
СообщениеДобавлено: 19 фев 2021, 23:01
Is GPU dead?
СообщениеДобавлено: 20 фев 2021, 01:29
Is GPU dead?
Mem - 100%, GPU - 100%, PL - 75..80%. Furmark. Results?
Marking MOSFETs (up + down) ?
СообщениеДобавлено: 20 фев 2021, 02:28
On mem 100% (normal clocks) gpu 100% (normal clocks) and pl +75% (175%) in furmark black screen after 15sec.
Mosfets are aon 6508 and aon 6414a
---------- Добавлено спустя 43 секунды: ----------
If u mean that clock and power :)
---------- Добавлено спустя 3 минуты 6 секунд: ----------
Oh i read bad, with power set to 75% - 30 sec in furmark and black screen.
---------- Добавлено спустя 2 минуты 21 секунду: ----------
Strange for me is that I need to wait a while (3-5minutes) with psu power off to start card again after black screen, look like some capacitor or something like that?
СообщениеДобавлено: 20 фев 2021, 04:05
But if mem=75%, GPU=100%, PL=75% all is Ok?
...or tempetarute?
СообщениеДобавлено: 20 фев 2021, 13:44
I mounted again heatsink and with that setting as you write black screen in furmark was after 90 seconds. Temperature of gpu before black screen was about 55/60c degree.
СообщениеДобавлено: 20 фев 2021, 15:30
not GPU, but MOSFETs
СообщениеДобавлено: 20 фев 2021, 17:11
So how to check mosfet temperatures?
СообщениеДобавлено: 21 фев 2021, 01:13
Thermal imager, thermocouple, pyrometer... finger.
For your MOSFETs - u better change them on analogs, but with Id more than 32A.
В этой теме нет новых непрочитанных сообщений. GTX 980Ti G1 Gaming white screens
TomaszR
17 авг 2021, 16:35
Сц Гост Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. palit gtx 560 2gb
kob1991
29 ноя 2021, 17:59
kob1991 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Помогите с сорванными элементами Видеокарта Gigabyte GeForce GTX 1080 Ti GAMING OC BLACK [GV-N108TGAMINGOC BLA
maxiss1987
2085
13 авг 2019, 17:25
maxiss1987 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte GTX 1080 Ti GAMING OC BLACK (не определяется, просадка по питанию 1.8v)
LO-master
05 май 2020, 19:05
LO-master Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gigabyte GA-G31M-ES2C rev: 1.1 Strange bios fault on the motherboard
в форуме Gigabyte
eletmoraes
13 апр 2017, 16:26
practicezerg Перейти к последнему сообщению
Сейчас этот форум просматривают: dani82, deacon, Sidney, titanium70rus и гости: 28
