Зарегистрирован: 12 мар 2021, 17:06 Наличности на руках: 9.08 Сообщения: 9 Откуда: Iraq
Hello all
i have a rtx 3090 that is not detected in pc the problem happened when i was trying to connect a new fan and accidently hit the graphic card and it got out of pci slot a little bit while it was working after that the GPU never worked only fans spin and no image and not detected tried on other motherboard and same thing i measured all voltages on the card and they are all normal and also the GPU heats up normally. is the gpu dead or there is something else could cause this and i also tried a new bios flash with programmer and same thing
kindly would you please help me if there is something else i could check
thanks in advance and best regards
JooereX
Заголовок сообщения: Re: Galax RTX 3090 not detected
Добавлено: 30 апр 2021, 11:03
Зарегистрирован: 27 мар 2021, 09:18 Наличности на руках: 71.58 Сообщения: 156
hello, are the pci conduits in place?
Mosasha
Добавлено: 01 май 2021, 04:01
hi sorry for the late replay i measured the resistance of all pci data lines and they all have resistance and the caps on the back all in place thanks
Mosasha
Добавлено: 05 май 2021, 01:04
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 35
