bokin021 писал(а):
some hellp?
Try to test the card using mods. You have to put your card in the second slot of MB then put another card in the first slot or use internal graphic to get the image.
Take the ISO from these theme
viewtopic.php?f=48&t=110020 You can use mods like ./mods gputest.js -oqa -old_gold -dramclk_percent 100 -fan_speed 80 -run_on_error -test 3
This let you test the card by mats through mods with maximum of memory clocks
