Заголовок сообщения: Asus rx570 gaming strix strang problem
Добавлено: 03 окт 2021, 18:49
Зарегистрирован: 20 сен 2021, 00:22 Наличности на руках: 70.01 Сообщения: 32 Откуда: Serbia
Hello
First time write here.
I have asus rx570 with strange problem. It have artifacts in windows in regular use, in furmark many artifacts but not crash or freeze or die. All voltages and resistance are in spec. Bios flashed and ok. Is that GPU related problem?
In tserver first 3-5 minutes before comes warmer all bank passes all the time, after 5 min all the banks show error.
vov4ik_il
Заголовок сообщения: Re: Asus rx570 gaming strix strang problem
Добавлено: 03 окт 2021, 18:52
Зарегистрирован: 12 май 2020, 04:22 Наличности на руках: 30.09 Сообщения: 25 Откуда: Бугор (за)
Sounds like partial main IC separation. Try reflow.
Sent from my iPhone using Tapatalk
nikolavik
Добавлено: 03 окт 2021, 21:05
Thanks, that is my last option if there is not any solution.
uncledim
