Текущее время: 20 май 2024, 02:15
 Заголовок сообщения: Nvidia P104-100
СообщениеДобавлено: 07 окт 2021, 15:43
Hi to all!
I have a p104-100 (flashed with 8gb bios) not working, on windows i see ti like a video accelerator and when i try to install the drivers i gave a blue screen, if i install it on safe boot mode i give a ble screen at the restrart...
On hiveos it detect it like gp104, but when miner start it say no gpu selcted or supported and goes to loop...
All the voltages present on the pbc, im trying to run mats, but gputest say erro:heatstresstest is not defined, an if i try to run mats -n i give an error say adatper not found with index 1 or similar....
Any help its appreciated !!!
 Заголовок сообщения: Re: Nvidia P104-100
СообщениеДобавлено: 08 окт 2021, 04:17
Bios is not fetched by the GPU and by extension by the motherboard. Please check pin 1 of the bios whether you have pulses on the /CS pin. I have such cards which stopped communicating with the bios chip and I can't find a solution. All voltages are in place but bios signals are silent.
СообщениеДобавлено: 08 окт 2021, 04:26
Для теста mats - ввести команду -3d_card
1: карту первой
2: монитор в мать, если есть встройка
3: матс400, запуск, до командной строки
4: "./mods gputest.js -skip_rm_state_init -oqa"
5: Enter
6: "./mats -3d_card -e 20"
7: Enter
это с форума инструкция
mods не запустится так как модифицированный биос под 8 гигабайт а стоковый биос - под 4 гигабайта Можно зашить биос стоковой прошивкой и проверить mods
СообщениеДобавлено: 16 окт 2021, 11:35
Oh my, i dont know why i havebìnt received the mail for the reply on this topic, many thanks to the tips!
Im still trying to revive this card... :D
Posted after 2 hours 32 minutes 20 seconds:
Ive tryed what have you tell to me, (ive flashed a stock bios first (i think))
First ive entered the -3d_card command but system say command not found
second ive entered the gputest, and i receive the same referenceerror: heatstresstest is not defined
then ive run mats -3dcard matstart, say running on a 3d controller card
mats version 400.xxx. testing gp104 with 20mb of memory starting with 0mb.
After few minutes i give fail screen, with error code:00000001
Im doing something wrong??
Many many thanks to your help
СообщениеДобавлено: 16 окт 2021, 19:45
Tryed mats (thanks to crocodile), and pass the test (on the report file i read some error on writing)
What i have to check now? i have a dead gpu??
Pandemonium6
I cant understand what i have to check, i havent an oscilloscope, i have a multimeter only...
i have to read the pin1 of the bios chip??
Many thanks to all of you guys, i love to fix this things when happen :D
СообщениеДобавлено: 16 окт 2021, 23:52
photo of the result test -please
СообщениеДобавлено: 17 окт 2021, 09:49
Sure! i copy the report file of mats below (without the bits of the error):
mats version 367.106. Testing GP104 with 20 MB of memory starting with 0 MB.
Read Error Count: 0
Write Error Count: 1712849
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 0 0
FBIOA1 0 0 0
FBIOB0 0 0 0
FBIOB1 0 0 0
FBIOC0 0 409410 0
FBIOC1 0 0 0
FBIOD0 0 449769 0
FBIOD1 0 853670 0
Failing Bits:
C008 C009 C010 C011 C012 C013 C014 C015 D024 D025 D026 D027 D028 D029 D030 D031
D040 D041 D042 D043 D044 D045 D046 D047 D056 D057 D058 D059 D060 D061 D062 D063
=== MEMORY ERRORS BY BIT ===
P : Partition (FBIO)
READ 0 READ 1 READ ?
P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1 EXP. 0 EXP. ?
C 008 0 87014 0 86982 32 0
C 009 0 541507 0 7206 534301 0
C 010 0 62098 0 62066 32 0
C 011 0 6326 0 6262 64 0
C 012 0 155294 0 155262 32 0
C 013 0 75580 0 75516 64 0
C 014 0 53633 0 53601 32 0
C 015 0 34866 0 34802 64 0
D 024 0 40932 0 32 40900 0
D 025 0 696259 0 40861 655398 0
D 026 0 202342 0 161442 40900 0
D 027 0 80836 0 44 80792 0
D 028 0 202342 0 161442 40900 0
D 029 0 162518 0 81726 80792 0
D 030 0 121637 0 80737 40900 0
D 031 0 201496 0 120704 80792 0
D 040 0 121706 0 80814 40892 0
D 041 0 736341 0 40593 695748 0
D 042 0 116759 0 75867 40892 0
D 043 0 736341 0 40593 695748 0
D 044 0 40974 0 82 40892 0
D 045 0 80892 0 90 80802 0
D 046 0 121706 0 80814 40892 0
D 047 0 121750 0 40948 80802 0
D 056 0 48882 0 13273 35609 0
D 057 0 677949 0 27859 650090 0
D 058 0 103140 0 67531 35609 0
D 059 0 88844 0 13330 75514 0
D 060 0 183872 0 148263 35609 0
D 061 0 144042 0 68528 75514 0
D 062 0 183872 0 148263 35609 0
D 063 0 144042 0 68528 75514 0
=== MEMORY ERRORS BY ADDRESS ===
ADDRESS : Failing memory address, or buffer offset if starting with 'X+'
T : Type of memory error: W = write, R = read
S : Subpartition
B : Bank
E : Beat
U : PseudoChannel
Error Code = 00000000 (OK)
СообщениеДобавлено: 17 окт 2021, 15:38
first step - reballing memory, control of date and address lines, Maybe
replacement memory .
second step - video chip - reballing
СообщениеДобавлено: 17 окт 2021, 16:28
Then it could be a vram issue?
Many thanks i think I had to send to a reballer (i havent the irda station...)
СообщениеДобавлено: 17 окт 2021, 23:36
of course - memory GPU 50 / 50
В этой теме нет новых непрочитанных сообщений. Помогите узнать smd-элементы и их номиналы Nvidia P104-100 4CB
wukill
03 янв 2021, 13:41
wukill Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. VRAM Gtx1080 8gb and zotac p104-100-A1 4gb
lantrung1983
23 ноя 2019, 23:38
lantrung1983 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Как протестировать память P104-100 Mats
[ На страницу: 1, 2 ]
tolychik
35
9606
23 фев 2024, 21:29
Сисадмин Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. INNO3D P104-100 нет питаний
Sergio83
10
1993
19 авг 2020, 11:19
dron102 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI P104-100 4Gb
instal86
12
2167
01 дек 2021, 21:39
Vetal36 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 24
