gtx1060 pny 6gb no voltage memory https://vlab.su/viewtopic.php?f=48&t=120764 |
bokin021 [ 17 ноя 2021, 21:37 ] | |
Заголовок сообщения: | gtx1060 pny 6gb no voltage memory |
Hi I have issue with graphic card ..I dont see 1.5v memory and voltage GPU all voltage are PCI -E 3.3 5v 1.8v 12 v. 1.8 v bios ..Memory is around 43.0 ohm ,GPU 0.6 ohm .I test all fuses ..On RT8128C missing enable I cant found out ,from where come ..Please help..Thanks |
aleksros [ 17 ноя 2021, 22:48 ] | |
Заголовок сообщения: | Re: gtx1060 pny 6gb no voltage memory |
bokin021 писал(а): Memory is around 0.43 ohm it's bad. or memory or gpu - is dead (or both) |
bokin021 [ 17 ноя 2021, 22:51 ] | |
why you think ?I wrote wrong memory is 43 ohm no 0.43 |
aleksros [ 17 ноя 2021, 23:10 ] | |
it was a quote. if it was written 0.43, then it was. and if you misspelled it, this is different, you can edit it at least ten times - the quote will remain a quote)). then 43 ohms is the norm. that's not the problem)) look for memory power pwm. see the availability of the enable, pwm power supply. |
bokin021 [ 17 ноя 2021, 23:15 ] | |
Yea ,but RT8128C should present voltage for memory and on 7 pin i dont see voltage 0.35 should be more ..I cant see from where come EN |
aleksros [ 18 ноя 2021, 01:19 ] | |
bokin021 писал(а): I cant see from where come EN Take a photo of the board on both sides in good quality. Let's try to find where the turn-on signal comes from. |
bokin021 [ 18 ноя 2021, 06:53 ] | |
Ok I did photo |
bokin021 [ 18 ноя 2021, 20:32 ] | |
I also measure on GPU controller EN 0.2v .. |
aleksros [ 18 ноя 2021, 21:25 ] | |
bokin021 писал(а): I also measure on GPU controller EN 0.2v .. ))what else did they keep silent about? first, the power supply of the GPU should rise, and only then the memory. what is the voltage at all pins sd8 sd9 |
bokin021 [ 18 ноя 2021, 21:59 ] | |
Or should firs rise memory and then GPU?I will tomorrow check voltage.. |
bokin021 [ 19 ноя 2021, 13:12 ] | |
i mesure voltage |
aleksros [ 19 ноя 2021, 13:20 ] | |
bokin021 писал(а): i mesure voltage good, but wrong. I asked to measure on sd8 sd9, but not sq9 and sq10. |
bokin021 [ 19 ноя 2021, 17:38 ] | |
now i will do i m sory..But I cant see sd9 Posted after 14 minutes 2 seconds: i mesure now.. Posted after 8 minutes 19 seconds: I mark it |
aleksros [ 20 ноя 2021, 02:16 ] | |
0,7v - it's wrong. in green - it's result in blue - it's cause. we must find it. use schematic in picture. |
bokin021 [ 20 ноя 2021, 09:57 ] | |
When I inject 0.9v on this coil what I mark now i got gpu and memory voltage ..I cant understand for this shematic .. |
aleksros [ 20 ноя 2021, 12:10 ] | |
bokin021 писал(а): When I inject 0.9v on this coil what I mark now i got gpu and memory voltage because pgood from it is a necessary condition for raising the voltage of the GPU and memory. |
bokin021 [ 20 ноя 2021, 12:11 ] | |
i cant find pgood source .. |
aleksros [ 20 ноя 2021, 12:32 ] | |
take a foto this place. I see only light spot. |
bokin021 [ 20 ноя 2021, 12:48 ] | |
Ok I did new photo.. |
aleksros [ 20 ноя 2021, 13:10 ] | |
check privat message |
