Gigabyte rx480 gaming g1 https://vlab.su/viewtopic.php?f=48&t=121704 |
amkwca [ 18 дек 2021, 17:24 ] | |
Заголовок сообщения: | Gigabyte rx480 gaming g1 |
I'm getting 1.8v missing on that card. I ckecked GS7103 linear regulator it has vdd and vin but missing the signal enable. I followed the signal should come from a transistor MMBT3904 S1AH and replaced but still no enable volt. replaced the Ic, same result. I measured resistance from pin En to ground, it's 0.7 k and I believe it's supposed to be 10k, I checked all resistors and capacitors in range to find a faulty one but didn't find. Anybody can help? |
Pandemonium6 [ 18 дек 2021, 19:08 ] | |
Заголовок сообщения: | Re: Gigabyte rx480 gaming g1 |
What is the resistance on 1.8V itself? |
amkwca [ 18 дек 2021, 21:48 ] | |
I think it's normal. it's 3.9 k from 1.8v pin and ground. any idea? |
aleksros [ 19 дек 2021, 00:31 ] | |
amkwca писал(а): but still no enable volt open schematic or boardview and find enable |
amkwca [ 19 дек 2021, 03:01 ] | |
I don't have schematic for that card but enable comes from the dual transistor and I changed it with no results |
Pandemonium6 [ 19 дек 2021, 06:59 ] | |
There is schematic for RX-590 and looks the same as you describe on page 21 here: Gigabyte GV-RX590 GME-8GD Rev: 1.0 Схема viewtopic.php?f=48&t=2118 Page has description (19) POWER MANAGEMENT The same regulator and the same NPN transistor |
amkwca [ 19 дек 2021, 08:42 ] | |
I tried something now, I should share with you. I put external power 3.3v to pin EN from a bench power supply and I tried the card on the motherboard and measured volts, I'm having now the 3.3v at pin EN and accordingly I got 1.8v at pin 7 finally. I measured volts after, I'm getting PEX volt 0.9v and I'm still missing vcore, vram and v ram controller. Any idea? I'm so exited |
aleksros [ 19 дек 2021, 15:11 ] | |
amkwca bardview in privat message. it's from msi but similar )) take for us foto your card from bottom side near U300 and Q210 Q1010 |
Pandemonium6 [ 19 дек 2021, 21:30 ] | |
This schematic is probably good. You have to follow these signals backwards. This 1.8V_EN is formed by at least 3 other circuits built on NPN discrete transistors. You have to follow them all. |
