Текущее время: 27 апр 2024, 17:55
 Заголовок сообщения: GTX 660 Ti Gigabyte - no voltage on Vram
СообщениеДобавлено: 23 дек 2021, 19:23
Hello.
I bought a cheap damaged graphics card (GV-N66TOC-2GD) to be repaired. I think it's flooded. The PC does not recognize the card. After checking the voltage on the core is about 0.9 V and on Vram 0 V. The resistance on the Vram lines looks good (about 90 Ohm).
I located and replaced the defective 0 Ohm resistor (R628) but nothing has changed. I also replaced the ncp5392p chip with a new one.
The mosfets and drivers of the mosfets seem to be working .
Maybe GPU flooding can lower the voltage on Vram to 0 V?
Does anyone have schematic to this card?
 Заголовок сообщения: Re: GTX 660 Ti Gigabyte - no voltage on Vram
СообщениеДобавлено: 03 янв 2022, 22:05
Warus23
Hello, maybe need resoldering or replacing this ic:
СообщениеДобавлено: 10 дек 2023, 21:31
Hello! I got absolute identical situation, on same card.
Voltage of memory do not appears, an VCORE is about 0.9v.
This is my old broken videocard, Idk what happens with it, but I have no picture on screen and probably no voltage on VMEM could be a problem.
I will try to follow recomendations and resolder controller or electrical key that recommended to resolder e.t.c.
I still not found boardview for concretly this videocard, even in 2023.
If anyone have boardview for GV-N66TOC 2 or 3GD, please, help.
Thank you all for your help! :co_ol:
СообщениеДобавлено: 01 фев 2024, 00:22
Did you managed to fix it ?, i also have a waterdamaged GPU that i need to fix
В этой теме нет новых непрочитанных сообщений. gigabyte gtx 1050 низкое напряжение на nvvdd - gigabyte gtx 1050 low voltage on nvvdd
TheMArcos
16 мар 2021, 16:28
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte GTX 1070 Mini memory voltage missing
Erminb
16
1806
15 сен 2021, 20:18
Quasar047 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte 660 нет питания vccp
Vahrumka
17
7486
13 авг 2017, 16:56
clockerkz Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. проблема с zotac gtx 660
ДИМИТРИЙ888
03 фев 2016, 11:44
ДИМИТРИЙ888 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Сбиты элементы на MSI GTX 660
StarDim
23 мар 2016, 03:03
StarDim Перейти к последнему сообщению
Сейчас этот форум просматривают: gildan87, ShowMeYourSkills, Yandex [BOT], Yellow-Glaze и гости: 39
