Текущее время: 09 май 2024, 03:21
PT-AH
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 26 янв 2022, 16:53 |
Сообщения: 97 Откуда: England
Pandemonium6 писал(а): You don't have good electric circuits in England anyway.
I do this as a hobby and this gpu came from portugal. yes I'm checking... I've already found 3 burnt chips
PT-AH
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 27 янв 2022, 17:04 |
Pandemonium6 писал(а): In most cases several PCI-e lanes are killed along with PEX voltage rail which means the dead GPU.
yes it is the most certain to have killed the gpu. burnt chips were up9511p, display port, up7549p, bios and 2 capacitors behind the gpu chip. at the beginning 1.8V had 0.0ohms shorted to GND. at the moment I have 3.4 ohms of difference to the gnd, not letting it be short anyway.
PT-AH
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 28 янв 2022, 04:25 |
Pandemonium6 писал(а): 3.4 ohms means dead GPU correct. I have all the voltages now, the chip heats up but does not detect. just replacing taking advantage of another burned PCB. :(
PT-AH
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 28 янв 2022, 20:19 |
Pandemonium6 писал(а): 3.4 ohms means dead GPU. What are other resistances on all voltage rails? What about integrity of PCI-e signals? I have a doubt. unsolder the 1080ti bga graphics chip and checked all 1.8V. it seems that only the 1.8v main is shorted in the marked area, on the other side there is 1.8v main with 2.8 K ohm. If using UV ink to block that pinout area will it work? Photo: https://ibb.co/NCDHj9c
Pandemonium6
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 28 янв 2022, 20:41 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,140.72
Сообщения: 762 Откуда: Holand
I don't think it will work. As Albert Einstein joked about the moon When you don't look at it it does not exist It was about a quantum theory but your mental experiment looks familiar haha. Yes, your analysis of the problem is very good anyway. It shows that a part of the GPU, powered from the 1.8V is dead. It may be something important and I doubt it will work But of course try...
PT-AH
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 29 янв 2022, 19:28 |
Pandemonium6 писал(а): Sim, sua análise do problema é muito boa de qualquer maneira. Mostra que uma parte da GPU, alimentada pelo 1.8V está morta. Pode ser algo importante e duvido que dê certo Mas claro que tente... It doesn't hurt to try, really, and then I'll only know if it works. I've done some weird scenes and it worked. Maybe it will, after trying I'll let you know the result. I will deal with it soon.
PT-AH
Заголовок сообщения: Re: Gigabyte GTX 1080 TI Gaming OC 11GB 1.8V problem (Boardviwer?) Добавлено: 29 янв 2022, 21:32 |
Pandemonium6 писал(а): Deve haver um circuito diferente que esteja em curto e não seja relevante para os outros 1.8V_MAIN I went to look for the TEXAS instruments chest and VDD18 (VR_GEN) which is this area that burned when the GPU owner was playing with VR_mode. It is an External Power for using the VR glasses when you need more performance than usual. By research, I can pull out that circuit. The GPU may work fine, but the VR mode will not work properly. Photo: https://ibb.co/nq2TSHX
