Текущее время: 28 апр 2024, 22:41
SemSever
Заголовок сообщения: Re: Palit RTX3060ti DUAL проблемы с сигналом EN Добавлено: 09 фев 2022, 11:26 |
Сообщения: 96 Откуда: Челябинск
Pandemonium6 писал(а): There is voltage divider 10k to 1V8 and 10k to ground. It means 10k/(10k+10k) = 0.5. So every input voltage will be divided by half. In your schematic you have 1V8 so the input voltage should be 0.9V. The pull-up resistor to 1.8V R822 is not soldered on the board, according to the diagram it is also not there.
Pandemonium6
Заголовок сообщения: Re: Palit RTX3060ti DUAL проблемы с сигналом EN Добавлено: 09 фев 2022, 18:55 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,140.72
Сообщения: 762 Откуда: Holand
OK, Please read the schematic corectly. There is a label over the line to the EN pin marked as "PS_NVVDD_EN_R". It means that there is something connected to it somewhere. It is electrical connection but for clarity they did not draw a line. Follow this label.... Posted after 7 minutes 18 seconds:PS_NVVDD_EN_R -> PS_NVVDD_AND_IN2 and a note: uPi EN has internal PU to 2.4V. When you analyze the PDF of this uPi PWM. Connecting a power directly to this pin can kill it. So be careful and always read manual
SemSever
Заголовок сообщения: Re: Palit RTX3060ti DUAL проблемы с сигналом EN Добавлено: 09 фев 2022, 19:51 |
Pandemonium6 писал(а): PS_NVVDD_EN_R -> PS_NVVDD_AND_IN2 and a note: uPi EN has internal PU to 2.4V. When you analyze the PDF of this uPi PWM. Connecting a power directly to this pin can kill it. So be careful and always read manual Yes, I also came to the conclusion that the EN signal is generated in the controller itself in the POR section. And yes, the datasheet says that the signal cannot be pulled up directly, I did it the way it was concluded in the last service that the GPU was not working. After my manipulation, the card started up - the drivers were installed, but did not give a load. Already, too, I tend to think that there are some problems in the load of the controller. I installed a known-good controller - the behavior did not change.
Normalgleb
Заголовок сообщения: Re: Palit RTX3060ti DUAL проблемы с сигналом EN Добавлено: 09 авг 2022, 15:29 |
Зарегистрирован: 28 мар 2016, 15:55 Наличности на руках: -2.92
Сообщения: 109 Откуда: Алматы
motor_58 писал(а): чем дело закончилось? есть проблема с 1660 super 2.4в то появляются, то пропадают. 12, 5, 3.3, 1.8 есть всегда, если 2.4 появились на En шим 9512 то все напряжения оставшиеся появляются и карта работает, полностью проходит тесты. У меня также, не было даже 1.8в. видюха с алика, как купили не заработал. Лдо 1.8 потрогал щупом теперь 1.8в есть. Но через раз пгуд шим памяти UP9512r не появляется
