GTX 1070 evga sc https://vlab.su/viewtopic.php?f=48&t=125861 |
PT-AH [ 17 май 2022, 14:23 ] | |
Заголовок сообщения: | GTX 1070 evga sc |
it has all the voltages, when I connect it to the pc, it sends small starts on the fan. same on second gpu is not detected Helps? |
brk [ 19 май 2022, 00:45 ] | |
Заголовок сообщения: | Re: GTX 1070 evga sc |
check differential lines for example. If you got trouble with first ones on PCI-E slot you can try to change platform. Use AMD Motherboard if you currently use INTEL one. AMD make check another PCI-E lines to find videocard. |
