Текущее время: 26 май 2024, 20:50
TheMArcos
Заголовок сообщения: Re: component identification help Добавлено: 28 июл 2020, 06:10 |
Зарегистрирован: 18 мар 2020, 04:02 Наличности на руках: 21.68
Сообщения: 184 Откуда: Brasil
thanks madking, I managed to make this Vpex and Vmem board, but Without Vgpu, could you help me find the possible fault, and what pins should I check on the PWM Up9501S? some pins: 1 - 70mv 2 - 2.34v 3 - 76mv 4 - 50mv 5 - 0 6 - 2mv 7 - 0 8 - 0 12 - 1.12v 17 - 1v 18 - 5v 20 - 0 37 -12v 47 - 3.3v 48 - 3.3v what else to check?
madking
Заголовок сообщения: Re: component identification help Добавлено: 28 июл 2020, 10:20 |
Зарегистрирован: 03 ноя 2017, 01:24 Наличности на руках: 5,012.04
Сообщения: 3986 Откуда: Budapest
TheMArcos писал(а): 3 - 76mv EN - no normal search 5pin logic ic
TheMArcos
Заголовок сообщения: Re: component identification help Добавлено: 29 июл 2020, 08:36 |
madking писал(а): TheMArcos wrote: 3 - 76mv
EN - no normal search 5pin logic ic sorry, I made a mess, in reality pin 2 has 76mv and pin 3 has 2.34V
TheMArcos
Заголовок сообщения: Re: component identification help Добавлено: 02 авг 2020, 22:05 |
ilie321 писал(а): Posted: 31 Jul 2020, 04:42 outputs open drain since they use resistor to vcc and also arrows are pointing to outside also check in pdf the enable voltage 2.4 seams strange value I didn’t find the pdf on google, these images I took from the upi website, I’ve already checked the entire enable line and I couldn’t notice anything unusual, I was looking at the image and I saw that there are pins TP (11) and TM (21) , should there be any tension on these pins? what is his function? thanks for listening.
Conqueror
Заголовок сообщения: Re: component identification help Добавлено: 02 авг 2020, 22:54 |
Зарегистрирован: 18 фев 2018, 11:28 Наличности на руках: 142.23
Сообщения: 168 Откуда: Иркутская область
TheMArcos писал(а): what is his function? here they are: Test Pin & Thermal Monitoring
men2k1
Заголовок сообщения: Re: component identification help Добавлено: 03 авг 2020, 06:10 |
Зарегистрирован: 28 июл 2019, 08:05 Наличности на руках: 193.41
Сообщения: 166 Откуда: Ю-С
TheMArcos писал(а): do you have the complete pdf of this datasheet? if you have can you make me available? datasheet
Conqueror
Заголовок сообщения: Re: component identification help Добавлено: 03 авг 2020, 23:18 |
TheMArcos писал(а): do you have the complete pdf of this datasheet? if you have can you make me available? This is NOT a up9501 datasheet, this is a uPi1608 datasheet - but it's similar as the uPi1608P by pin assignments. So one time we changed them well between ASUS Strix GTX950 & ASUS Dual GTX1060 )))) Вложение: up1608pq-ds-f0104.zip
