Текущее время: 28 апр 2024, 16:14
 Заголовок сообщения: MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error
СообщениеДобавлено: 13 июл 2022, 10:59
Hi everyone. As the title says. I have 3 GPUS ( MSI, XFX, SAPPHIRE RX 580 ). All of them have memory bank errors on D0 & D1 according to TSERVER.
The issue is that i have replaced the memory of D0 & D1 from the donor board and also from aliexpress. But still, I get the same error. It is starting to blow my mind now what else is causing the issue. I checked the memory lines continuity with the donor board and everything seemed fine and normal. Anyone else with the same problem please share your thoughts on it. Thank you
 Заголовок сообщения: Re: MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error
СообщениеДобавлено: 13 июл 2022, 13:25
ll_r1d0_ll
Remove the GPU and memory, and look for a break along the lines D0 & D1, when you find it, restore it. There may be a broken track or transition.
现在的也越来越难修啊,生意真是不好做啊!
© Конфуций из Шэньчжэня
СообщениеДобавлено: 13 июл 2022, 13:53
com77 писал(а):
ll_r1d0_ll
Hi thanks for the response.
Without removing the main chip I measured each and every trace from a donor motherboard whose only mosfet section was blown. All the values seemed normal on each trace. I am trying to avoid removing the main chip because it will then take alot of effort remove the main chip then reball and reinstall. I was hoping if there would be any other method for testing or anyone who had the same issue like me.
СообщениеДобавлено: 15 июл 2022, 13:18
anyone else with the similar problem?
СообщениеДобавлено: 15 июл 2022, 13:25
ll_r1d0_ll
Yes, it's the same here:
viewtopic.php?f=48&t=112417
Remove the GPU and look for a break.
СообщениеДобавлено: 22 окт 2022, 19:10
com77 писал(а):
_r1d0_ll
Hello. Just to update it was the faulty resistor behind the memory . Replaced it and card booted up fine. Thanks for the reply
СообщениеДобавлено: 06 ноя 2022, 13:04
Hi, could you please tell me which resistor did you replace? I have the same problem, GPU and memories replaced but the problem persists, all the resistors seems to be fine :-(
В этой теме нет новых непрочитанных сообщений. Возможна замена чипа с RX 480 на RX 580 MSI RX 480 Gaming X 8 GB ?
Crimfell
09 май 2022, 09:05
hualei16888 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 05:42
black7705 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX 580 XXX 8GB memory resistance
nikolavik
1169
21 фев 2022, 23:38
nikolavik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire RX 580 8GB artifact memory or gpu ?
allas
26 окт 2020, 01:08
boblek Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sapphire RX 580 8GB Memory unknown
JoKeR125RUS
13
483
08 апр 2024, 14:39
1maikl1 Перейти к последнему сообщению
Сейчас этот форум просматривают: RadioYurchic, YunicheK и гости: 30
