Pandemonium6 писал(а):
What is the resistance of the vddcr_gfx ? Please measure on chokes, show me all measurements on the card.
You can connect USB005 to this 37217 and look what is going on. dump configuration. It is very easy to replace IR35217 and reprogram it. I had faulty PWM controllers maybe it is the case?
Resistance is around 0.3 ohm, but i think vddcr_gfx is vcore like other high end card always show 0.xxx ohm right?, so you reflash the firmware on IR35217 and it is working?, do you have the firmware IR35217 for this gigabyte RX5700?, thanks
