https://vlab.su/
Rx 6800xt asrock Taichi, black screen when installing drivers
https://vlab.su/viewtopic.php?f=48&t=129083
Страница 1 из 1
azzed [ 29 сен 2022, 10:21 ]
Заголовок сообщения:  Rx 6800xt asrock Taichi, black screen when installing drivers
Rx 6800xt asrock Taichi, black screen when installing drivers, I think it needs reflow on the gpu chip, any suggestions? - The gpu was used without support, the board looks a bit bent.
black7705 [ 01 окт 2022, 11:05 ]
Заголовок сообщения:  Re: Rx 6800xt asrock Taichi, black screen when installing drivers
Looks like the GPU is bad. What about measurements?
yusuf4511 [ 04 окт 2022, 21:04 ]
If it used without gpu support sounds like you have memory issue. Do memory test and share the result.
uncledim [ 04 окт 2022, 21:14 ]
https://youtu.be/37izQQJ_XS0?t=104
http://www.phpbb.com/
