Текущее время: 27 апр 2024, 15:28
 Заголовок сообщения: Help help Help memory samsung detect micron (domate)
СообщениеДобавлено: 29 окт 2022, 22:53
problem: I put a graphic on the pc and it was working fine with SAMSUNG MEMORIES. my friend put a vbios oc samsung techpowerup, but it gave an error. I re-entered the official bios and now it detects me as MICRON Memories.
Help
Private donate for repair information
 Заголовок сообщения: Re: Help help Help memory samsung detect micron (domate)
СообщениеДобавлено: 02 ноя 2022, 13:07
Write the model of the video card! Has the card been repaired?
 Заголовок сообщения: Re: Help help Help error driver power state failure and problem power status!
СообщениеДобавлено: 02 ноя 2022, 14:43
The part of finding the memory already figured out why not.
The bios was simply not being read correctly.
Grafic Card: https://tpucdn.com/gpu-specs/images/c/2860-front.jpg
Now I have another problem:
"error driver power state failure"
This error described above has to do with the problem that I'm always putting the GPU in maximum use, having an error in the power driver or something like that.
this event was caused by me accidentally on the laptop, I made a mistake putting the bios and damaged some control chip.
It installs the driver, gives the error after 2 minutes, when it restarts and goes into windows it leaves me the BLACK SCREEN.
foto: "https://ibb.co/fMB7RSb"
foto: "https://ibb.co/8srTC2H"
I can't find these chips: "56VD - T19D " 8pin and " GAW-SVL" second image.
if anyone has any MXM3.0 boardview or datasheet it would help a lot.
before having done this problem/screwed up:
foto: "https://ibb.co/RSX3GyZ"
That's because I have Prema Mod Bios since then
thank you for the help!!
В этой теме нет новых непрочитанных сообщений. asus rog gtx 1070 strix oc 8gb no detect memory
PT-AH
29 янв 2022, 00:17
SimbA Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS Strix Rx 470 8GB memory replacement micron.
allas
09 фев 2021, 02:17
allas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX2070 with Micron memory, random blackscreens after changing
Assassin
15
3369
01 окт 2020, 11:15
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 23:26
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 05:42
black7705 Перейти к последнему сообщению
Сейчас этот форум просматривают: CrD, gildan87, virus.tmn, Yellow-Glaze и гости: 41
