zoidberg
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 15 сен 2023, 13:14 |
Зарегистрирован: 15 июн 2016, 15:27 Наличности на руках: 52.19
Сообщения: 53 Откуда: Piter
YunicheK писал(а): NVMT вам в помощь. Спасибо огромное вам! Лог вынул, пока неясно что тут, но такое ощущение, что c1 прям весь ушел в аут
MT.LOG
Trying to operate on device specified in nvmt.fid: cat: can't open 'nvmt.fid': No such file or directory NVMT (LINUX Version: Fri Jul 1 09:42:43 2022) Copyright(C) NVidia Corp 2013-2022 Bus=0x01 Device=0x00 DEV&VID=0x220410de (NVidia GA102)* GA102 Temperature = 47'C GPU: GA102 DRAM: GDDR6X 512Mx2x8 / FB=24576MB VML CLK: 9752MHz BUS: 384 Bits RAMCFG: 3 CMD_MAP: 0xa MODE:PAM4 DFE:2/3/2 OB:OFFSET=+1 IB:OFFSET=+0 REG SET=2 | DQ | WCK/QS | CLKM |CMD&ADR|CALMST_RB ----------+----------+----------+----------+-------+---------- GPU TERM |P-UP(+04) |P-UP( +0) | | |0x3c DRV | +00/+00 | +00/+00 | +00/+00 |+00/+00|0x56/0x5a VREF |112/164/214| 197 OUTBD| 0 | 1 | 0 | 1 | INBD | 0 | 7 | DRAM ODT | OFF(+0) | OFF(+0) | CKE | 80(+0)| DRV | 40/40(+3/+3) |
MEM CFG: RANK = 2^0 = 1 ROW = 2^14 = 16384 COLUMN = 2^7 = 128 BANK = 2^4 = 16 BURST LENGTH = 16 AC Parameters (MCLK=9752Mhz;tCK=410ps;UI=51.3ps) : CL = 31(GPU) / 9(DRAM) WL = 7(GPU) / 7(DRAM) tRAS = 61 tRC = 98 tRFC = 269 tRFCpb = 122 tRREFD = 22 tRCDRD = 39 tRCDWR = 31 tRP = 37 tWR = 40(GPU) / 4(DRAM) tRTP = 3 tRRDS = 5 tRRDL = 10 tCCDS = 2 tCCDL = 3 tCCDR = 2 CRCRL = 4 CRCWL = 15 tWTR/tCDLR = 13 tFAW = 20 tCKE = 25 Max(tMRD,tMOD,tSDO) = 10 tPD/tPDEN2DEX = 10 tXP(DLL)/tPDEX/tXPN = 12 tRFCSBA(tRFCSB) = 122 tRFCSBR(tRREFD) = 22 REFRESH = 51 (1.89 us) tKO = 26 tLK = 40 GPU:GA102 DRAM:GDDR6X(24576MB) DRAMCLK:9752MHz ABI: 1 (GPU) 1 (DRAM) WR EDC: 1 (GPU) 0 (DRAM) RD EDC: 1 (GPU) 0 (DRAM) REPLAY: 1 ECC: 0 Periodic Train: 0 REFSB: 1 (DISPATCH=0.07us ABR=5*tREFI DELAY_THRESH=4*tREFI) EDC Tracking: 0 (RX_GAIN=1 TX_GAIN=1) VREF Tracking: 0 (GAIN=1) Pattern Shift: 0 (WR) 0 (RD) Period TR AVE: 0 (WR_Fact=4 RD_Fact=4) MTA: 1 (GPU) 0 (DRAM) ** LOCKED GA102 GDDR6X ** SUBP: A0A1B0B1C0C1D0D1E0E1F0F1 FBPA_GENERIC_MRS ,0x9a0300,0x00000027 FBPA_GENERIC_MRS1 ,0x9a0330,0x00100000 FBPA_GENERIC_MRS2 ,0x9a0334,0x002007db FBPA_GENERIC_MRS3 ,0x9a0338,0x00300000 FBPA_GENERIC_MRS4 ,0x9a033c,0x0040061f FBPA_GENERIC_MRS5 ,0x9a0340,0x00500100 FBPA_GENERIC_MRS6 ,0x9a0344,0x00600f9c FBPA_GENERIC_MRS7 ,0x9a0348,0x00700080 FBPA_GENERIC_MRS8 ,0x9a0354,0x00800013 FBPA_GENERIC_MRS9 ,0x9a0358,0x00900000 FBPA_GENERIC_MRS10,0x9a2200,0x00a00204 FBPA_GENERIC_MRS11,0x9a2204,0x00b00000 FBPA_GENERIC_MRS12,0x9a2208,0x00c00000 FBPA_GENERIC_MRS13,0x9a220c,0x00f00000 FBPA_GENERIC_MRS14,0x9a035c,0x00000080 FBPA_GENERIC_MRS15,0x9a034c,0x00f00000 DRAMCLK = 9751 MHz
ADDRESS Training Status: PA, PAD ,BRSFT,INTPL, MIN, MAX,TAP,WIN_CNT A0,IC0_CA0 , 1 , 45 ,2457,2457, 0, 9 A0,IC0_CA1 , 1 , 37 ,2457,2457, 0, 9 A0,IC0_CA2 , 1 , 41 ,2457,2457, 0, 9 A0,IC0_CA3 , 1 , 14 ,2457,2457, 0, 9 A0,IC0_CA4 , 1 , 41 ,2457,2457, 0, 9 A0,IC0_CA5 , 1 , 40 ,2457,2457, 0, 9 A0,IC0_CA6 , 1 , 29 ,2457,2457, 0, 9 A0,IC0_CA7 , 1 , 15 ,2457,2457, 0, 9 A0,IC0_CA8 , 1 , 47 ,2457,2457, 0, 9 A0,IC0_CABI, 1 , 45 ,2457,2457, 0, 9 A0,IC0_CA9 , 1 , 53 ,2457,2457, 0, 9 A0,IC1_CA0 , 1 , 55 ,2457,2457, 0, 9 A0,IC1_CA1 , 1 , 40 ,2457,2457, 0, 9 A0,IC1_CA2 , 1 , 58 ,2457,2457, 0, 9 A0,IC1_CA3 , 1 , 35 ,2457,2457, 0, 9 A0,IC1_CA4 , 1 , 62 ,2457,2457, 0, 9 A0,IC1_CA5 , 1 , 49 ,2457,2457, 0, 9 A0,IC1_CA6 , 1 , 24 ,2457,2457, 0, 9 A0,IC1_CA7 , 1 , 37 ,2457,2457, 0, 9 A0,IC1_CA8 , 1 , 42 ,2457,2457, 0, 9 A0,IC1_CABI, 1 , 48 ,2457,2457, 0, 9 A0,IC1_CA9 , 1 , 53 ,2457,2457, 0, 9 A1,IC0_CA0 , 1 , 51 ,2457,2457, 0, 9 A1,IC0_CA1 , 1 , 28 ,2457,2457, 0, 9 A1,IC0_CA2 , 1 , 32 ,2457,2457, 0, 9 A1,IC0_CA3 , 1 , 15 ,2457,2457, 0, 9 A1,IC0_CA4 , 1 , 43 ,2457,2457, 0, 9 A1,IC0_CA5 , 1 , 35 ,2457,2457, 0, 9 A1,IC0_CA6 , 1 , 11 ,2457,2457, 0, 9 A1,IC0_CA7 , 1 , 10 ,2457,2457, 0, 9 A1,IC0_CA8 , 1 , 31 ,2457,2457, 0, 9 A1,IC0_CABI, 1 , 30 ,2457,2457, 0, 9 A1,IC0_CA9 , 1 , 39 ,2457,2457, 0, 9 A1,IC1_CA0 , 1 , 54 ,2457,2457, 0, 9 A1,IC1_CA1 , 1 , 27 ,2457,2457, 0, 9 A1,IC1_CA2 , 1 , 32 ,2457,2457, 0, 9 A1,IC1_CA3 , 1 , 6 ,2457,2457, 0, 9 A1,IC1_CA4 , 1 , 39 ,2457,2457, 0, 9 A1,IC1_CA5 , 1 , 32 ,2457,2457, 0, 9 A1,IC1_CA6 , 1 , 8 ,2457,2457, 0, 9 A1,IC1_CA7 , 1 , 8 ,2457,2457, 0, 9 A1,IC1_CA8 , 1 , 54 ,2457,2457, 0, 9 A1,IC1_CABI, 1 , 36 ,2457,2457, 0, 9 A1,IC1_CA9 , 1 , 52 ,2457,2457, 0, 9 B0,IC0_CA0 , 1 , 3 ,2457,2457, 0, 9 B0,IC0_CA1 , 1 , 31 ,2457,2457, 0, 9 B0,IC0_CA2 , 1 , 20 ,2457,2457, 0, 9 B0,IC0_CA3 , 1 , 21 ,2457,2457, 0, 9 B0,IC0_CA4 , 1 , 37 ,2457,2457, 0, 9 B0,IC0_CA5 , 1 , 39 ,2457,2457, 0, 9 B0,IC0_CA6 , 1 , 24 ,2457,2457, 0, 9 B0,IC0_CA7 , 1 , 16 ,2457,2457, 0, 9 B0,IC0_CA8 , 1 , 17 ,2457,2457, 0, 9 B0,IC0_CABI, 1 , 24 ,2457,2457, 0, 9 B0,IC0_CA9 , 1 , 21 ,2457,2457, 0, 9 B0,IC1_CA0 , 1 , 16 ,2457,2457, 0, 9 B0,IC1_CA1 , 1 , 39 ,2457,2457, 0, 9 B0,IC1_CA2 , 1 , 31 ,2457,2457, 0, 9 B0,IC1_CA3 , 1 , 36 ,2457,2457, 0, 9 B0,IC1_CA4 , 1 , 24 ,2457,2457, 0, 9 B0,IC1_CA5 , 1 , 44 ,2457,2457, 0, 9 B0,IC1_CA6 , 1 , 36 ,2457,2457, 0, 9 B0,IC1_CA7 , 1 , 33 ,2457,2457, 0, 9 B0,IC1_CA8 , 1 , 32 ,2457,2457, 0, 9 B0,IC1_CABI, 1 , 27 ,2457,2457, 0, 9 B0,IC1_CA9 , 1 , 26 ,2457,2457, 0, 9 B1,IC0_CA0 , 1 , 26 ,2457,2457, 0, 9 B1,IC0_CA1 , 1 , 38 ,2457,2457, 0, 9 B1,IC0_CA2 , 1 , 34 ,2457,2457, 0, 9 B1,IC0_CA3 , 1 , 37 ,2457,2457, 0, 9 B1,IC0_CA4 , 1 , 21 ,2457,2457, 0, 9 B1,IC0_CA5 , 1 , 39 ,2457,2457, 0, 9 B1,IC0_CA6 , 1 , 39 ,2457,2457, 0, 9 B1,IC0_CA7 , 1 , 26 ,2457,2457, 0, 9 B1,IC0_CA8 , 1 , 13 ,2457,2457, 0, 9 B1,IC0_CABI, 1 , 25 ,2457,2457, 0, 9 B1,IC0_CA9 , 1 , 14 ,2457,2457, 0, 9 B1,IC1_CA0 , 1 , 18 ,2457,2457, 0, 9 B1,IC1_CA1 , 1 , 36 ,2457,2457, 0, 9 B1,IC1_CA2 , 1 , 19 ,2457,2457, 0, 9 B1,IC1_CA3 , 1 , 31 ,2457,2457, 0, 9 B1,IC1_CA4 , 1 , 34 ,2457,2457, 0, 9 B1,IC1_CA5 , 1 , 37 ,2457,2457, 0, 9 B1,IC1_CA6 , 1 , 20 ,2457,2457, 0, 9 B1,IC1_CA7 , 1 , 26 ,2457,2457, 0, 9 B1,IC1_CA8 , 1 , 14 ,2457,2457, 0, 9 B1,IC1_CABI, 1 , 21 ,2457,2457, 0, 9 B1,IC1_CA9 , 1 , 8 ,2457,2457, 0, 9 C0,IC0_CA0 , 1 , 25 , 273, 273, 0, 1 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 1 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 1 C0,IC0_CA3 , 1 , 2 ,2457,2457, 0, 9 C0,IC0_CA4 , 1 , 26 , 273, 273, 0, 1 C0,IC0_CA5 , 1 , 34 , 273, 273, 0, 1 C0,IC0_CA6 , 1 , 14 , 273, 273, 0, 1 C0,IC0_CA7 , 1 , 2 ,2457,2457, 0, 9 C0,IC0_CA8 , 3 , 63 , 273, 273, 0, 1 C0,IC0_CABI, 3 , 63 , 273, 273, 0, 1 C0,IC0_CA9 , 3 , 63 , 273, 273, 0, 1 C0,IC1_CA0 , 1 , 36 , 273, 273, 0, 1 C0,IC1_CA1 , 1 , 33 , 273, 273, 0, 1 C0,IC1_CA2 , 1 , 29 , 273, 273, 0, 1 C0,IC1_CA3 , 1 , 22 ,2457,2457, 0, 9 C0,IC1_CA4 , 1 , 46 , 273, 273, 0, 1 C0,IC1_CA5 , 1 , 28 , 273, 273, 0, 1 C0,IC1_CA6 , 1 , 11 , 273, 273, 0, 1 C0,IC1_CA7 , 1 , 29 ,2457,2457, 0, 9 C0,IC1_CA8 , 1 , 34 , 273, 273, 0, 1 C0,IC1_CABI, 1 , 42 , 273, 273, 0, 1 C0,IC1_CA9 , 1 , 35 , 273, 273, 0, 1 C1,IC0_CA0 , 1 , 42 , 0, 0, 0, 0 C1,IC0_CA1 , 1 , 22 , 0, 0, 0, 0 C1,IC0_CA2 , 1 , 32 , 0, 0, 0, 0 C1,IC0_CA3 , 1 , 24 ,2457,2457, 0, 9 C1,IC0_CA4 , 1 , 36 , 0, 0, 0, 0 C1,IC0_CA5 , 1 , 31 , 0, 0, 0, 0 C1,IC0_CA6 , 1 , 19 , 0, 0, 0, 0 C1,IC0_CA7 , 1 , 11 ,2457,2457, 0, 9 C1,IC0_CA8 , 1 , 28 , 0, 0, 0, 0 C1,IC0_CABI, 3 , 63 , 0, 0, 0, 0 C1,IC0_CA9 , 1 , 42 , 0, 0, 0, 0 C1,IC1_CA0 , 1 , 35 , 0, 0, 0, 0 C1,IC1_CA1 , 1 , 27 , 0, 0, 0, 0 C1,IC1_CA2 , 1 , 12 , 0, 0, 0, 0 C1,IC1_CA3 , 1 , 16 ,2457,2457, 0, 9 C1,IC1_CA4 , 1 , 30 , 0, 0, 0, 0 C1,IC1_CA5 , 1 , 26 , 0, 0, 0, 0 C1,IC1_CA6 , 1 , 1 , 0, 0, 0, 0 C1,IC1_CA7 , 1 , 6 ,2457,2457, 0, 9 C1,IC1_CA8 , 1 , 32 , 0, 0, 0, 0 C1,IC1_CABI, 1 , 25 , 0, 0, 0, 0 C1,IC1_CA9 , 1 , 32 , 0, 0, 0, 0 D0,IC0_CA0 , 1 , 16 ,2457,2457, 0, 9 D0,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 D0,IC0_CA2 , 1 , 27 ,2457,2457, 0, 9 D0,IC0_CA3 , 1 , 12 ,2457,2457, 0, 9 D0,IC0_CA4 , 1 , 15 ,2457,2457, 0, 9 D0,IC0_CA5 , 1 , 32 ,2457,2457, 0, 9 D0,IC0_CA6 , 1 , 19 ,2457,2457, 0, 9 D0,IC0_CA7 , 1 , 13 ,2457,2457, 0, 9 D0,IC0_CA8 , 1 , 2 ,2457,2457, 0, 9 D0,IC0_CABI, 1 , 21 ,2457,2457, 0, 9 D0,IC0_CA9 , 1 , 10 ,2457,2457, 0, 9 D0,IC1_CA0 , 1 , 28 ,2457,2457, 0, 9 D0,IC1_CA1 , 1 , 21 ,2457,2457, 0, 9 D0,IC1_CA2 , 1 , 22 ,2457,2457, 0, 9 D0,IC1_CA3 , 1 , 30 ,2457,2457, 0, 9 D0,IC1_CA4 , 1 , 27 ,2457,2457, 0, 9 D0,IC1_CA5 , 1 , 30 ,2457,2457, 0, 9 D0,IC1_CA6 , 1 , 32 ,2457,2457, 0, 9 D0,IC1_CA7 , 1 , 27 ,2457,2457, 0, 9 D0,IC1_CA8 , 1 , 13 ,2457,2457, 0, 9 D0,IC1_CABI, 1 , 34 ,2457,2457, 0, 9 D0,IC1_CA9 , 1 , 16 ,2457,2457, 0, 9 D1,IC0_CA0 , 1 , 28 ,2457,2457, 0, 9 D1,IC0_CA1 , 1 , 20 ,2457,2457, 0, 9 D1,IC0_CA2 , 1 , 27 ,2457,2457, 0, 9 D1,IC0_CA3 , 1 , 16 ,2457,2457, 0, 9 D1,IC0_CA4 , 1 , 31 ,2457,2457, 0, 9 D1,IC0_CA5 , 1 , 11 ,2457,2457, 0, 9 D1,IC0_CA6 , 1 , 16 ,2457,2457, 0, 9 D1,IC0_CA7 , 1 , 29 ,2457,2457, 0, 9 D1,IC0_CA8 , 1 , 13 ,2457,2457, 0, 9 D1,IC0_CABI, 1 , 30 ,2457,2457, 0, 9 D1,IC0_CA9 , 1 , 28 ,2457,2457, 0, 9 D1,IC1_CA0 , 1 , 15 ,2457,2457, 0, 9 D1,IC1_CA1 , 1 , 29 ,2457,2457, 0, 9 D1,IC1_CA2 , 1 , 15 ,2457,2457, 0, 9 D1,IC1_CA3 , 1 , 9 ,2457,2457, 0, 9 D1,IC1_CA4 , 1 , 25 ,2457,2457, 0, 9 D1,IC1_CA5 , 1 , 33 ,2457,2457, 0, 9 D1,IC1_CA6 , 1 , 13 ,2457,2457, 0, 9 D1,IC1_CA7 , 1 , 21 ,2457,2457, 0, 9 D1,IC1_CA8 , 1 , 15 ,2457,2457, 0, 9 D1,IC1_CABI, 1 , 20 ,2457,2457, 0, 9 D1,IC1_CA9 , 1 , 15 ,2457,2457, 0, 9 E0,IC0_CA0 , 1 , 28 ,2457,2457, 0, 9 E0,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 E0,IC0_CA2 , 1 , 24 ,2457,2457, 0, 9 E0,IC0_CA3 , 1 , 42 ,2457,2457, 0, 9 E0,IC0_CA4 , 1 , 39 ,2457,2457, 0, 9 E0,IC0_CA5 , 1 , 42 ,2457,2457, 0, 9 E0,IC0_CA6 , 1 , 43 ,2457,2457, 0, 9 E0,IC0_CA7 , 1 , 27 ,2457,2457, 0, 9 E0,IC0_CA8 , 1 , 25 ,2457,2457, 0, 9 E0,IC0_CABI, 1 , 26 ,2457,2457, 0, 9 E0,IC0_CA9 , 1 , 30 ,2457,2457, 0, 9 E0,IC1_CA0 , 1 , 19 ,2457,2457, 0, 9 E0,IC1_CA1 , 1 , 28 ,2457,2457, 0, 9 E0,IC1_CA2 , 1 , 38 ,2457,2457, 0, 9 E0,IC1_CA3 , 1 , 37 ,2457,2457, 0, 9 E0,IC1_CA4 , 1 , 23 ,2457,2457, 0, 9 E0,IC1_CA5 , 1 , 50 ,2457,2457, 0, 9 E0,IC1_CA6 , 1 , 33 ,2457,2457, 0, 9 E0,IC1_CA7 , 1 , 32 ,2457,2457, 0, 9 E0,IC1_CA8 , 1 , 36 ,2457,2457, 0, 9 E0,IC1_CABI, 1 , 30 ,2457,2457, 0, 9 E0,IC1_CA9 , 1 , 33 ,2457,2457, 0, 9 E1,IC0_CA0 , 1 , 27 ,2457,2457, 0, 9 E1,IC0_CA1 , 1 , 22 ,2457,2457, 0, 9 E1,IC0_CA2 , 1 , 9 ,2457,2457, 0, 9 E1,IC0_CA3 , 1 , 36 ,2457,2457, 0, 9 E1,IC0_CA4 , 1 , 24 ,2457,2457, 0, 9 E1,IC0_CA5 , 1 , 33 ,2457,2457, 0, 9 E1,IC0_CA6 , 1 , 27 ,2457,2457, 0, 9 E1,IC0_CA7 , 1 , 21 ,2457,2457, 0, 9 E1,IC0_CA8 , 1 , 15 ,2457,2457, 0, 9 E1,IC0_CABI, 1 , 32 ,2457,2457, 0, 9 E1,IC0_CA9 , 1 , 3 ,2457,2457, 0, 9 E1,IC1_CA0 , 1 , 12 ,2457,2457, 0, 9 E1,IC1_CA1 , 1 , 28 ,2457,2457, 0, 9 E1,IC1_CA2 , 1 , 23 ,2457,2457, 0, 9 E1,IC1_CA3 , 1 , 28 ,2457,2457, 0, 9 E1,IC1_CA4 , 1 , 31 ,2457,2457, 0, 9 E1,IC1_CA5 , 1 , 30 ,2457,2457, 0, 9 E1,IC1_CA6 , 1 , 23 ,2457,2457, 0, 9 E1,IC1_CA7 , 1 , 17 ,2457,2457, 0, 9 E1,IC1_CA8 , 1 , 11 ,2457,2457, 0, 9 E1,IC1_CABI, 1 , 34 ,2457,2457, 0, 9 E1,IC1_CA9 , 1 , 13 ,2457,2457, 0, 9 F0,IC0_CA0 , 1 , 14 ,2457,2457, 0, 9 F0,IC0_CA1 , 1 , 19 ,2457,2457, 0, 9 F0,IC0_CA2 , 1 , 19 ,2457,2457, 0, 9 F0,IC0_CA3 , 1 , 37 ,2457,2457, 0, 9 F0,IC0_CA4 , 1 , 34 ,2457,2457, 0, 9 F0,IC0_CA5 , 1 , 25 ,2457,2457, 0, 9 F0,IC0_CA6 , 1 , 36 ,2457,2457, 0, 9 F0,IC0_CA7 , 1 , 19 ,2457,2457, 0, 9 F0,IC0_CA8 , 1 , 8 ,2457,2457, 0, 9 F0,IC0_CABI, 1 , 22 ,2457,2457, 0, 9 F0,IC0_CA9 , 1 , 11 ,2457,2457, 0, 9 F0,IC1_CA0 , 1 , 27 ,2457,2457, 0, 9 F0,IC1_CA1 , 1 , 43 ,2457,2457, 0, 9 F0,IC1_CA2 , 1 , 28 ,2457,2457, 0, 9 F0,IC1_CA3 , 1 , 38 ,2457,2457, 0, 9 F0,IC1_CA4 , 1 , 24 ,2457,2457, 0, 9 F0,IC1_CA5 , 1 , 44 ,2457,2457, 0, 9 F0,IC1_CA6 , 1 , 24 ,2457,2457, 0, 9 F0,IC1_CA7 , 1 , 22 ,2457,2457, 0, 9 F0,IC1_CA8 , 1 , 16 ,2457,2457, 0, 9 F0,IC1_CABI, 1 , 25 ,2457,2457, 0, 9 F0,IC1_CA9 , 1 , 25 ,2457,2457, 0, 9 F1,IC0_CA0 , 1 , 39 ,2457,2457, 0, 9 F1,IC0_CA1 , 1 , 41 ,2457,2457, 0, 9 F1,IC0_CA2 , 1 , 52 ,2457,2457, 0, 9 F1,IC0_CA3 , 1 , 23 ,2457,2457, 0, 9 F1,IC0_CA4 , 1 , 42 ,2457,2457, 0, 9 F1,IC0_CA5 , 1 , 29 ,2457,2457, 0, 9 F1,IC0_CA6 , 1 , 23 ,2457,2457, 0, 9 F1,IC0_CA7 , 1 , 30 ,2457,2457, 0, 9 F1,IC0_CA8 , 1 , 34 ,2457,2457, 0, 9 F1,IC0_CABI, 1 , 51 ,2457,2457, 0, 9 F1,IC0_CA9 , 1 , 44 ,2457,2457, 0, 9 F1,IC1_CA0 , 1 , 41 ,2457,2457, 0, 9 F1,IC1_CA1 , 1 , 25 ,2457,2457, 0, 9 F1,IC1_CA2 , 1 , 29 ,2457,2457, 0, 9 F1,IC1_CA3 , 1 , 15 ,2457,2457, 0, 9 F1,IC1_CA4 , 1 , 36 ,2457,2457, 0, 9 F1,IC1_CA5 , 1 , 33 ,2457,2457, 0, 9 F1,IC1_CA6 , 1 , 31 ,2457,2457, 0, 9 F1,IC1_CA7 , 1 , 27 ,2457,2457, 0, 9 F1,IC1_CA8 , 1 , 40 ,2457,2457, 0, 9 F1,IC1_CABI, 1 , 37 ,2457,2457, 0, 9 F1,IC1_CA9 , 1 , 42 ,2457,2457, 0, 9
WCK2CK Training Status: PA,SIGNAL,DLY,Last Early,First Late,Delta A ,WCK01 , 0, 153 , 153 , 0 A ,WCKB01, 0, 153 , 153 , 0 A ,WCK23 , 0, 153 , 153 , 0 A ,WCKB23, 0, 153 , 153 , 0 A ,WCK45 , 0, 153 , 153 , 0 A ,WCKB45, 0, 153 , 153 , 0 A ,WCK67 , 0, 153 , 153 , 0 A ,WCKB67, 0, 153 , 153 , 0 B ,WCK01 , 0, 153 , 153 , 0 B ,WCKB01, 0, 153 , 153 , 0 B ,WCK23 , 0, 153 , 153 , 0 B ,WCKB23, 0, 153 , 153 , 0 B ,WCK45 , 0, 153 , 153 , 0 B ,WCKB45, 0, 153 , 153 , 0 B ,WCK67 , 0, 153 , 153 , 0 B ,WCKB67, 0, 153 , 153 , 0 C ,WCK01 , 0, 17 , 17 , 0 C ,WCKB01, 0, 17 , 17 , 0 C ,WCK23 , 0, 17 , 17 , 0 C ,WCKB23, 0, 153 , 153 , 0 C ,WCK45 , 0, 0 , 0 , 0 C ,WCKB45, 0, 0 , 0 , 0 C ,WCK67 , 0, 0 , 0 , 0 C ,WCKB67, 0, 153 , 153 , 0 D ,WCK01 , 0, 153 , 153 , 0 D ,WCKB01, 0, 153 , 153 , 0 D ,WCK23 , 0, 153 , 153 , 0 D ,WCKB23, 0, 153 , 153 , 0 D ,WCK45 , 0, 153 , 153 , 0 D ,WCKB45, 0, 153 , 153 , 0 D ,WCK67 , 0, 153 , 153 , 0 D ,WCKB67, 0, 153 , 153 , 0 E ,WCK01 , 0, 153 , 153 , 0 E ,WCKB01, 0, 153 , 153 , 0 E ,WCK23 , 0, 153 , 153 , 0 E ,WCKB23, 0, 153 , 153 , 0 E ,WCK45 , 0, 153 , 153 , 0 E ,WCKB45, 0, 153 , 153 , 0 E ,WCK67 , 0, 153 , 153 , 0 E ,WCKB67, 0, 153 , 153 , 0 F ,WCK01 , 0, 153 , 153 , 0 F ,WCKB01, 0, 153 , 153 , 0 F ,WCK23 , 0, 153 , 153 , 0 F ,WCKB23, 0, 153 , 153 , 0 F ,WCK45 , 0, 153 , 153 , 0 F ,WCKB45, 0, 153 , 153 , 0 F ,WCK67 , 0, 153 , 153 , 0 F ,WCKB67, 0, 153 , 153 , 0
READ Training Status: ,PA,PAD ,BS,IPL,MIN,MAX,PASS,WIN IB ,A0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ00,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ01,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ02,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ04,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ05,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ06,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI0,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ08,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ09,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ10,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ12,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ13,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ14,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI1,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ16,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ17,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ18,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ20,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ21,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ22,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI2,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ24,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ25,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ26,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ28,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ29,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ30,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ32,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ33,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ34,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ36,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ37,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ38,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DBI4,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ40,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ41,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ42,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ44,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ45,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ46,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DBI5,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ48,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ49,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ50,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ52,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ53,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ54,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DBI6,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ56,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ57,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ58,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ60,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ61,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ62,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI7,29, 0,2457,2457, 1,9,*** Warning ****
WRITE Training Status: ,PA,PAD ,BS,IPL,MIN,MAX,PAS,WIN OB ,A0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ00, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ01, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ02, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ03, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ04, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ05, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ06, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ07, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI0, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ08, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ09, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ10, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ11, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ12, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ13, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ14, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ15, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI1, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ16,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ17,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ18,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ20,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ21,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ22,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI2,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ24, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ25, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ26, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ27, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ28, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ29, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ30, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ31, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI3, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ32, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ33, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ34, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ35, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ36, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ37, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ38, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ39, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DBI4, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ40,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ41,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ42,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ44,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ45,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ46,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DBI5,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ48, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ49, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ50, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ51, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ52, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ53, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ54, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ55, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DBI6, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ56, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ57, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ58, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ59, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ60, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ61, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ62, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ63, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DBI7, 3, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ00, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ01, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ02, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ03, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ04, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ05, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ06, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ07, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI0, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ08, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ09, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ10, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ11, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ12, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ13, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ14, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ15, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI1, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ16, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ17, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ18, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ19, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ20, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ21, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ22, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ23, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI2, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ40, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ41, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ42, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ43, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ44, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ45, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ46, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ47, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI5, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ48, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ49, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ50, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ51, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ52, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ53, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ54, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ55, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI6, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI7,11, 0,2457,2457, 1,9,*** Warning ****
CLKM = 9752.00 MHz; GDDR6X MODE 1 Command Mapping: SUBP0 | SUBP1 , A0, A1, B0, B1, C0, C1, D0, D1, E0, E1, F0, F1 PAD00:CA8A|PAD28:CA8B,111,118, 81, 78,255, 96, 66, 79, 89, 75, 72,104 PAD01:CA0A|PAD29:CA0B,109,118, 67, 82, 89, 99, 80, 79, 92, 76, 78,105 PAD02:CA9A|PAD30:CA9B,117,116, 85, 72,255, 96, 74, 79, 94, 77, 75,106 PAD03:RST*|PAD31:RST*, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64 PAD04:CA9B|PAD32:CA9A,117,103, 90, 78, 99,106, 80, 92, 97, 67, 89,108 PAD05:CA0B|PAD33:CA0A,119,115, 80, 90,100,106, 92, 92, 83, 91, 91,103 PAD06:CA8B|PAD34:CA8A,106, 95, 96, 77, 98, 92, 77, 77,100, 79, 80, 98 PAD07:CA4B|PAD35:CA2A,126, 96, 88, 98,110, 96, 91, 91, 87, 73, 88,116 PAD08:CA2B|PAD36:CA4A,122,107, 95, 85, 93,100, 86, 95,102, 88, 92,106 PAD09:ABIB|PAD37:ABIA,112, 94, 91, 89,106,255, 98, 94, 94, 96, 89,115 PAD10:ABIA|PAD38:ABIB,109,100, 88, 85,255, 89, 85, 84, 90, 98, 86,101 PAD11:CA2A|PAD39:CA4B,105,103, 84, 98, 98, 94, 91, 89, 88, 95, 83,100 PAD12:CA4A|PAD40:CA2B,105, 96,101, 83, 90, 76, 79, 79,103, 87, 98, 93 PAD13:CKEA|PAD41:CKEB, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64 PAD14:CA1A|PAD42:CA5B,101, 96, 95,101, 83, 90, 89, 97, 89, 94, 83, 97 PAD15:CA5A|PAD43:CA1B,104, 91,103,100, 98, 91, 96, 93,106, 92, 89, 89 PAD16:CA5B|PAD44:CA1A,113, 92,108,102, 92, 86, 94, 84,114, 86,108,105 PAD17:CA1B|PAD45:CA5A,104, 99,103,103, 97, 95, 85, 75, 92, 97,107, 93 PAD18:CKEB|PAD46:CEKA, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64 PAD19:CA7B|PAD47:CA3A,101, 79, 97,101, 93, 88, 91, 80, 96,100, 86, 87 PAD20:CA3B|PAD48:CA7A, 99, 74,100, 90, 86, 75, 94, 93,101, 85,102, 94 PAD21:CA6B|PAD49:CA6A, 88, 75,100,103, 75, 83, 96, 80, 97, 91, 88, 87 PAD22:CA6A|PAD50:CA6B, 93, 72, 88, 84, 78, 65, 83, 77,107, 87,100, 95 PAD23:CA7A|PAD51:CA3B, 79, 70, 80, 95, 66, 80, 77, 73, 91, 92, 83, 79 PAD24:CA3A|PAD52:CA7B, 78, 72, 85, 90, 66, 70, 76, 85,106, 81,101, 91
---------- Добавлено спустя 3 часа 50 минут 36 секунд: ---------- Сейчас скинул чипы с обоих сторон и с соседнего канала - замеры абсолютно одинаковые, пятаки целы и до чипа примерно 300ом по всем линиям связи до гпу что здесь может быть не так? попробую еще с соседнего канала рабочего подкинуть ---------- Добавлено спустя 45 минут 16 секунд: ---------- после ребола памяти и подкидывания с рабочего канала вот такая картина, с1 вообще пропал с радаров, попробую поднять гпу все же
лог трейнинга
B1,IC1_CA8 , 1 , 13 ,2457,2457, 0, 9 B1,IC1_CABI, 1 , 20 ,2457,2457, 0, 9 B1,IC1_CA9 , 1 , 8 ,2457,2457, 0, 9 C0,IC0_CA0 , 1 , 26 , 273, 273, 0, 0 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 0 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 0 C0,IC0_CA3 , 1 , 3 ,2457,2457, 0, 9 C0,IC0_CA4 , 1 , 26 , 273, 273, 0, 0 C0,IC0_CA5 , 1 , 35 , 273, 273, 0, 0 C0,IC0_CA6 , 1 , 14 , 273, 273, 0, 0 C0,IC0_CA7 , 3 , 63 ,2457,2457, 0, 9 C0,IC0_CA8 , 3 , 63 , 273, 273, 0, 0 C0,IC0_CABI, 3 , 63 , 273, 273, 0, 0 C0,IC0_CA9 , 3 , 63 , 273, 273, 0, 0 C0,IC1_CA0 , 1 , 36 , 273, 273, 0, 0 C0,IC1_CA1 , 1 , 34 , 273, 273, 0, 0 C0,IC1_CA2 , 1 , 29 , 273, 273, 0, 0 C0,IC1_CA3 , 1 , 22 ,2457,2457, 0, 9 C0,IC1_CA4 , 1 , 47 , 273, 273, 0, 0 C0,IC1_CA5 , 1 , 28 , 273, 273, 0, 0 C0,IC1_CA6 , 1 , 12 , 273, 273, 0, 0 C0,IC1_CA7 , 1 , 29 ,2457,2457, 0, 9 C0,IC1_CA8 , 1 , 35 , 273, 273, 0, 0 C0,IC1_CABI, 1 , 42 , 273, 273, 0, 0 C0,IC1_CA9 , 1 , 36 , 273, 273, 0, 0 C1,IC0_CA0 , 1 , 45 , 0, 0, 0, 0 C1,IC0_CA1 , 1 , 22 , 0, 0, 0, 0 C1,IC0_CA2 , 1 , 32 , 0, 0, 0, 0 C1,IC0_CA3 , 1 , 24 , 0, 0, 0, 0 C1,IC0_CA4 , 1 , 36 , 0, 0, 0, 0 C1,IC0_CA5 , 1 , 31 , 0, 0, 0, 0 C1,IC0_CA6 , 1 , 22 , 0, 0, 0, 0 C1,IC0_CA7 , 1 , 11 , 0, 0, 0, 0 C1,IC0_CA8 , 1 , 28 , 0, 0, 0, 0 C1,IC0_CABI, 3 , 63 , 0, 0, 0, 0 C1,IC0_CA9 , 1 , 42 , 0, 0, 0, 0 C1,IC1_CA0 , 1 , 36 , 0, 0, 0, 0 C1,IC1_CA1 , 1 , 29 , 0, 0, 0, 0 C1,IC1_CA2 , 1 , 13 , 0, 0, 0, 0 C1,IC1_CA3 , 1 , 16 , 0, 0, 0, 0 C1,IC1_CA4 , 1 , 32 , 0, 0, 0, 0 C1,IC1_CA5 , 1 , 28 , 0, 0, 0, 0 C1,IC1_CA6 , 1 , 2 , 0, 0, 0, 0 C1,IC1_CA7 , 1 , 7 , 0, 0, 0, 0 C1,IC1_CA8 , 1 , 34 , 0, 0, 0, 0 C1,IC1_CABI, 3 , 63 , 0, 0, 0, 0 C1,IC1_CA9 , 1 , 33 , 0, 0, 0, 0 D0,IC0_CA0 , 1 , 16 ,2457,2457, 0, 9
madking
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 15 сен 2023, 18:29 |
Зарегистрирован: 03 ноя 2017, 01:24 Наличности на руках: 5,009.03
Сообщения: 3983 Откуда: Budapest
zoidberg писал(а): C0,IC0_CA0 , 1 , 26 , 273, 273, 0, 0 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 0 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 0 это тоже ошибки если что
zoidberg
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 15 сен 2023, 21:24 |
Зарегистрирован: 15 июн 2016, 15:27 Наличности на руках: 52.19
Сообщения: 53 Откуда: Piter
madking писал(а): zoidberg писал(а): C0,IC0_CA0 , 1 , 26 , 273, 273, 0, 0 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 0 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 0
это тоже ошибки если что Да я в курсе. Снял гпу - все прекрасно, пятаки все вызвонил и они в полном порядке. Сейчас остынет, проверю, если ошибки останутся то поменяю все 4 чипа в канале с заведомо рабочей с 3080. Если так же останется, то значит это гпу ---------- Добавлено спустя 21 минуту 9 секунд: ---------- после ребола ситуация та же
мт
B1,IC1_CA8 , 1 , 12 ,2457,2457, 0, 9 B1,IC1_CABI, 1 , 20 ,2457,2457, 0, 9 B1,IC1_CA9 , 1 , 8 ,2457,2457, 0, 9 C0,IC0_CA0 , 1 , 25 , 273, 273, 0, 1 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 1 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 1 C0,IC0_CA3 , 1 , 3 ,2457,2457, 0, 9 C0,IC0_CA4 , 1 , 27 , 273, 273, 0, 1 C0,IC0_CA5 , 1 , 34 , 273, 273, 0, 1 C0,IC0_CA6 , 1 , 15 , 273, 273, 0, 1 C0,IC0_CA7 , 1 , 7 ,2457,2457, 0, 9 C0,IC0_CA8 , 1 , 14 , 273, 273, 0, 1 C0,IC0_CABI, 3 , 63 , 273, 273, 0, 1 C0,IC0_CA9 , 3 , 63 , 273, 273, 0, 1 C0,IC1_CA0 , 1 , 35 , 273, 273, 0, 1 C0,IC1_CA1 , 1 , 34 , 273, 273, 0, 1 C0,IC1_CA2 , 1 , 29 , 273, 273, 0, 1 C0,IC1_CA3 , 1 , 22 ,2457,2457, 0, 9 C0,IC1_CA4 , 1 , 47 , 273, 273, 0, 1 C0,IC1_CA5 , 1 , 28 , 273, 273, 0, 1 C0,IC1_CA6 , 1 , 11 , 273, 273, 0, 1 C0,IC1_CA7 , 1 , 29 ,2457,2457, 0, 9 C0,IC1_CA8 , 1 , 34 , 273, 273, 0, 1 C0,IC1_CABI, 1 , 41 , 273, 273, 0, 1 C0,IC1_CA9 , 1 , 35 , 273, 273, 0, 1 C1,IC0_CA0 , 1 , 44 , 0, 0, 0, 0 C1,IC0_CA1 , 1 , 23 , 0, 0, 0, 0 C1,IC0_CA2 , 1 , 32 , 0, 0, 0, 0 C1,IC0_CA3 , 1 , 24 , 0, 0, 0, 0 C1,IC0_CA4 , 1 , 36 , 0, 0, 0, 0 C1,IC0_CA5 , 1 , 31 , 0, 0, 0, 0 C1,IC0_CA6 , 1 , 21 , 0, 0, 0, 0 C1,IC0_CA7 , 1 , 12 , 0, 0, 0, 0 C1,IC0_CA8 , 1 , 28 , 0, 0, 0, 0 C1,IC0_CABI, 3 , 63 , 0, 0, 0, 0 C1,IC0_CA9 , 1 , 42 , 0, 0, 0, 0 C1,IC1_CA0 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA1 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA2 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA3 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA4 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA5 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA6 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA7 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA8 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CABI, 3 , 63 , 0, 0, 0, 0 C1,IC1_CA9 , 3 , 63 , 0, 0, 0, 0 D0,IC0_CA0 , 1 , 15 ,2457,2457, 0, 9 D0,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9
---------- Добавлено спустя 1 час 7 минут 12 секунд: ---------- Не уверен, что это причина, сейчас проверю заведомо рабочие чипы памяти, но на углу кристалла как раз рядом с каналом С есть вот такой скол. Возможно владелец когда-то пережал и конул его Вложение: Снимок экрана 2023-09-15 в 21.50.18.jpg ---------- Добавлено спустя 50 минут 21 секунду: ---------- И так, вместо D8BGX (3090) были поставлены D8BWW (3080) и в результате вот какая картина
мтлог
B1,IC1_CA5 , 1 , 37 ,2457,2457, 0, 9 B1,IC1_CA6 , 1 , 20 ,2457,2457, 0, 9 B1,IC1_CA7 , 1 , 26 ,2457,2457, 0, 9 B1,IC1_CA8 , 1 , 12 ,2457,2457, 0, 9 B1,IC1_CABI, 1 , 20 ,2457,2457, 0, 9 B1,IC1_CA9 , 1 , 8 ,2457,2457, 0, 9 C0,IC0_CA0 , 1 , 27 , 273, 273, 0, 0 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 0 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 0 C0,IC0_CA3 , 1 , 4 ,2457,2457, 0, 9 C0,IC0_CA4 , 1 , 27 , 273, 273, 0, 0 C0,IC0_CA5 , 1 , 35 , 273, 273, 0, 0 C0,IC0_CA6 , 1 , 15 , 273, 273, 0, 0 C0,IC0_CA7 , 3 , 63 ,2457,2457, 0, 9 C0,IC0_CA8 , 3 , 63 , 273, 273, 0, 0 C0,IC0_CABI, 3 , 63 , 273, 273, 0, 0 C0,IC0_CA9 , 3 , 63 , 273, 273, 0, 0 C0,IC1_CA0 , 1 , 37 , 273, 273, 0, 0 C0,IC1_CA1 , 1 , 35 , 273, 273, 0, 0 C0,IC1_CA2 , 1 , 30 , 273, 273, 0, 0 C0,IC1_CA3 , 1 , 22 ,2457,2457, 0, 9 C0,IC1_CA4 , 1 , 48 , 273, 273, 0, 0 C0,IC1_CA5 , 1 , 30 , 273, 273, 0, 0 C0,IC1_CA6 , 1 , 15 , 273, 273, 0, 0 C0,IC1_CA7 , 1 , 26 ,2457,2457, 0, 9 C0,IC1_CA8 , 1 , 36 , 273, 273, 0, 0 C0,IC1_CABI, 1 , 41 , 273, 273, 0, 0 C0,IC1_CA9 , 1 , 37 , 273, 273, 0, 0 C1,IC0_CA0 , 1 , 43 ,2457,2457, 0, 9 C1,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 C1,IC0_CA2 , 1 , 33 ,2457,2457, 0, 9 C1,IC0_CA3 , 1 , 27 , 0, 0, 0, 0 C1,IC0_CA4 , 1 , 36 ,2457,2457, 0, 9 C1,IC0_CA5 , 1 , 32 ,2457,2457, 0, 9 C1,IC0_CA6 , 1 , 22 ,2457,2457, 0, 9 C1,IC0_CA7 , 1 , 14 , 0, 0, 0, 0 C1,IC0_CA8 , 1 , 29 ,2457,2457, 0, 9 C1,IC0_CABI, 1 , 34 ,2457,2457, 0, 9 C1,IC0_CA9 , 1 , 42 ,2457,2457, 0, 9 C1,IC1_CA0 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA1 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA2 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA3 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA4 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA5 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA6 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA7 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA8 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CABI, 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA9 , 3 , 63 ,2457,2457, 0, 9 D0,IC0_CA0 , 1 , 16 ,2457,2457, 0, 9 D0,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 D0,IC0_CA2 , 1 , 27 ,2457,2457, 0, 9 D0,IC0_CA3 , 1 , 12 ,2457,2457, 0, 9
У кого есть соображения по теме? Попробовать поставить снятые чипы в другой канал и проверить уже работоспособность уже там или эти чипы не совместимы с собой? Что-то мне очень не верится, что скол кристалла мог так пагубно сказаться на этих ошибках Вот для сравнения слева до замены и справа после. В C0 ничего не поменялось, зато в С1 ошибок стало гораздо меньше. Ну загадка прям Чисто теоретически память должна быть совместима 3080/3090 Вложение: Снимок экрана 2023-09-15 в 22.45.16.jpg ---------- Добавлено спустя 40 минут 15 секунд: ---------- CA3 - CA7 вот такая закономерность прям если взглянуть на скрины
madking
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 02:01 |
zoidberg писал(а): Чисто теоретически память должна быть совместима 3080/3090 3080---D8BGW, which decodes to MT61K256M32JE-19:T. They are specified to run at 1188 MHz (19 Gbps GDDR6X effective). 3090--- D8BZC, which decodes to MT61K512M32KPA-21:U. They are specified to run at 1313 MHz (21 Gbps GDDR6 effective).
zoidberg
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 02:04 |
На сколько есть шанс того, что на конкретно этой доске каналы могут идти нестандартно? gigabyte AORUS GeForce RTX3090 XTREME WATERFORCE WB 24G Еще есть мысль зашить биос с отключенным каналом С и посмотреть на тепловизе те вообще чипы ли греются под нагрузкой madking писал(а): 3090--- D8BZC, which decodes to MT61K512M32KPA-21:U. They are specified to run at 1313 MHz (21 Gbps GDDR6 effective). на этой 3090 стоит D8BGX Но я уверен что в такой разнице в скорости не отразится на ошибках в трейнинге Вот какие я использовал D8BGX----- MT61K256M32JE-21------------3090 D8BWW-----MT61K256M32JE-19G-----------3080
madking
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 02:19 |
короче смотрю и не вижу, вы не то смотрите по сути, надо ниже смотреть и там смотреть изменения кому-то делал разяснения, вот так будет ясней замеры проводить, и понятно какой пятак за что отвечает Вложение: RAM position.jpg ---------- Добавлено спустя 6 минут 59 секунд: ---------- zoidberg писал(а): На сколько есть шанс того, что на конкретно этой доске каналы могут идти нестандартно? так если есть замеры по пятакам, то и можно узнать как их расположили, вопрос в другом если карта с водянкой может протекла и сгнили проходы, вот и реагирует на прогрев
zoidberg
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 02:44 |
madking писал(а): вопрос в другом если карта с водянкой может протекла и сгнили проходы, вот и реагирует на прогрев Там история у карты интересная, человек зачем-то посадил ее в EKWB водоблок кривыми руками, было сбито пару элементов по питанию. Про залитие не помню, но сама плата с завода покрыта хорошим слоем лака полимерного, поэтому под чипами и гпу вообще картина прекрасная, чистота. Ну и резюков гнилых не узрел
madking
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 11:22 |
zoidberg писал(а): было сбито пару элементов по питанию а в каком районе были сбиты элементы?
zoidberg
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 16:02 |
madking писал(а): а в каком районе были сбиты элементы? Вложение: Снимок экрана 2023-09-16 в 14.40.50.jpg А ТУТ все нормально с обратной стороны Вложение: Снимок экрана 2023-09-16 в 15.03.26.jpg
zoidberg
Заголовок сообщения: Re: RTX3080/3090 memory training errors вопрос Добавлено: 16 сен 2023, 17:43 |
madking писал(а): лишком много конденсаторов возле С1, под микроскопом провертье не сверху а сбоку нет ли трещин на конденсаторах В том и дело, что все кондеры запараллелены по FBVDDQ и 1.8вольт и больше там ничего, резюки тоже в поряде сейчас попробую скинуть 4 чипа с рабочего канала и запаяю туда те снятые. Надеюсь ошибка будет ---------- Добавлено спустя 1 час 11 минут 21 секунду: ---------- Поменял память из неисправных каналов в исправные - в последних никаких ошибок нет и это означает полностью рабочую память Значит снимаю полностью весь канал C и звоню на обрывы с обоих сторон платы. Запускаю плату на столе, смотрю все напруги. Может даже есть смысл осциллом потыкать Еще нашел интересную штуку, может на С1 нету клока? судя по логу Вложение: Снимок экрана 2023-09-16 в 17.47.26.jpg Ну и традиционный полный лог
мтлог
Trying to operate on device specified in nvmt.fid: cat: can't open 'nvmt.fid': No such file or directory NVMT (LINUX Version: Fri Jul 1 09:42:43 2022) Copyright(C) NVidia Corp 2013-2022 Bus=0x01 Device=0x00 DEV&VID=0x220410de (NVidia GA102)* GA102 Temperature = 38'C GPU: GA102 DRAM: GDDR6X 512Mx2x8 / FB=24576MB VML CLK: 9752MHz BUS: 384 Bits RAMCFG: 3 CMD_MAP: 0xa MODE:PAM4 DFE:2/3/2 OB:OFFSET=+1 IB:OFFSET=+0 REG SET=2 | DQ | WCK/QS | CLKM |CMD&ADR|CALMST_RB ----------+----------+----------+----------+-------+---------- GPU TERM |P-UP(+04) |P-UP( +0) | | |0x3e DRV | +00/+00 | +00/+00 | +00/+00 |+00/+00|0x56/0x58 VREF |112/164/214| 197 OUTBD| 0 | 1 | 0 | 1 | INBD | 0 | 7 | DRAM ODT | OFF(+0) | OFF(+0) | CKE | 80(+0)| DRV | 40/40(+3/+3) |
MEM CFG: RANK = 2^0 = 1 ROW = 2^14 = 16384 COLUMN = 2^7 = 128 BANK = 2^4 = 16 BURST LENGTH = 16 AC Parameters (MCLK=9752Mhz;tCK=410ps;UI=51.3ps) : CL = 31(GPU) / 9(DRAM) WL = 7(GPU) / 7(DRAM) tRAS = 61 tRC = 98 tRFC = 269 tRFCpb = 122 tRREFD = 22 tRCDRD = 39 tRCDWR = 31 tRP = 37 tWR = 40(GPU) / 4(DRAM) tRTP = 3 tRRDS = 5 tRRDL = 10 tCCDS = 2 tCCDL = 3 tCCDR = 2 CRCRL = 4 CRCWL = 15 tWTR/tCDLR = 13 tFAW = 20 tCKE = 25 Max(tMRD,tMOD,tSDO) = 10 tPD/tPDEN2DEX = 10 tXP(DLL)/tPDEX/tXPN = 12 tRFCSBA(tRFCSB) = 122 tRFCSBR(tRREFD) = 22 REFRESH = 51 (1.89 us) tKO = 26 tLK = 40 GPU:GA102 DRAM:GDDR6X(24576MB) DRAMCLK:9752MHz ABI: 1 (GPU) 1 (DRAM) WR EDC: 1 (GPU) 0 (DRAM) RD EDC: 1 (GPU) 0 (DRAM) REPLAY: 1 ECC: 0 Periodic Train: 0 REFSB: 1 (DISPATCH=0.07us ABR=5*tREFI DELAY_THRESH=4*tREFI) EDC Tracking: 0 (RX_GAIN=1 TX_GAIN=1) VREF Tracking: 0 (GAIN=1) Pattern Shift: 0 (WR) 0 (RD) Period TR AVE: 0 (WR_Fact=4 RD_Fact=4) MTA: 1 (GPU) 0 (DRAM) ** LOCKED GA102 GDDR6X ** SUBP: A0A1B0B1C0C1D0D1E0E1F0F1 FBPA_GENERIC_MRS ,0x9a0300,0x00000027 FBPA_GENERIC_MRS1 ,0x9a0330,0x00100000 FBPA_GENERIC_MRS2 ,0x9a0334,0x002007db FBPA_GENERIC_MRS3 ,0x9a0338,0x00300000 FBPA_GENERIC_MRS4 ,0x9a033c,0x0040061f FBPA_GENERIC_MRS5 ,0x9a0340,0x00500100 FBPA_GENERIC_MRS6 ,0x9a0344,0x00600f9c FBPA_GENERIC_MRS7 ,0x9a0348,0x00700080 FBPA_GENERIC_MRS8 ,0x9a0354,0x00800013 FBPA_GENERIC_MRS9 ,0x9a0358,0x00900000 FBPA_GENERIC_MRS10,0x9a2200,0x00a00204 FBPA_GENERIC_MRS11,0x9a2204,0x00b00000 FBPA_GENERIC_MRS12,0x9a2208,0x00c00000 FBPA_GENERIC_MRS13,0x9a220c,0x00f00000 FBPA_GENERIC_MRS14,0x9a035c,0x00000080 FBPA_GENERIC_MRS15,0x9a034c,0x00f00000 DRAMCLK = 9751 MHz
ADDRESS Training Status: PA, PAD ,BRSFT,INTPL, MIN, MAX,TAP,WIN_CNT A0,IC0_CA0 , 1 , 45 ,2457,2457, 0, 9 A0,IC0_CA1 , 1 , 38 ,2457,2457, 0, 9 A0,IC0_CA2 , 1 , 41 ,2457,2457, 0, 9 A0,IC0_CA3 , 1 , 15 ,2457,2457, 0, 9 A0,IC0_CA4 , 1 , 41 ,2457,2457, 0, 9 A0,IC0_CA5 , 1 , 39 ,2457,2457, 0, 9 A0,IC0_CA6 , 1 , 29 ,2457,2457, 0, 9 A0,IC0_CA7 , 1 , 15 ,2457,2457, 0, 9 A0,IC0_CA8 , 1 , 47 ,2457,2457, 0, 9 A0,IC0_CABI, 1 , 44 ,2457,2457, 0, 9 A0,IC0_CA9 , 1 , 53 ,2457,2457, 0, 9 A0,IC1_CA0 , 1 , 55 ,2457,2457, 0, 9 A0,IC1_CA1 , 1 , 40 ,2457,2457, 0, 9 A0,IC1_CA2 , 1 , 58 ,2457,2457, 0, 9 A0,IC1_CA3 , 1 , 35 ,2457,2457, 0, 9 A0,IC1_CA4 , 1 , 61 ,2457,2457, 0, 9 A0,IC1_CA5 , 1 , 49 ,2457,2457, 0, 9 A0,IC1_CA6 , 1 , 24 ,2457,2457, 0, 9 A0,IC1_CA7 , 1 , 38 ,2457,2457, 0, 9 A0,IC1_CA8 , 1 , 42 ,2457,2457, 0, 9 A0,IC1_CABI, 1 , 48 ,2457,2457, 0, 9 A0,IC1_CA9 , 1 , 52 ,2457,2457, 0, 9 A1,IC0_CA0 , 1 , 51 ,2457,2457, 0, 9 A1,IC0_CA1 , 1 , 28 ,2457,2457, 0, 9 A1,IC0_CA2 , 1 , 32 ,2457,2457, 0, 9 A1,IC0_CA3 , 1 , 15 ,2457,2457, 0, 9 A1,IC0_CA4 , 1 , 44 ,2457,2457, 0, 9 A1,IC0_CA5 , 1 , 35 ,2457,2457, 0, 9 A1,IC0_CA6 , 1 , 11 ,2457,2457, 0, 9 A1,IC0_CA7 , 1 , 11 ,2457,2457, 0, 9 A1,IC0_CA8 , 1 , 31 ,2457,2457, 0, 9 A1,IC0_CABI, 1 , 31 ,2457,2457, 0, 9 A1,IC0_CA9 , 1 , 39 ,2457,2457, 0, 9 A1,IC1_CA0 , 1 , 53 ,2457,2457, 0, 9 A1,IC1_CA1 , 1 , 27 ,2457,2457, 0, 9 A1,IC1_CA2 , 1 , 33 ,2457,2457, 0, 9 A1,IC1_CA3 , 1 , 7 ,2457,2457, 0, 9 A1,IC1_CA4 , 1 , 38 ,2457,2457, 0, 9 A1,IC1_CA5 , 1 , 32 ,2457,2457, 0, 9 A1,IC1_CA6 , 1 , 8 ,2457,2457, 0, 9 A1,IC1_CA7 , 1 , 8 ,2457,2457, 0, 9 A1,IC1_CA8 , 1 , 54 ,2457,2457, 0, 9 A1,IC1_CABI, 1 , 37 ,2457,2457, 0, 9 A1,IC1_CA9 , 1 , 52 ,2457,2457, 0, 9 B0,IC0_CA0 , 1 , 3 ,2457,2457, 0, 9 B0,IC0_CA1 , 1 , 31 ,2457,2457, 0, 9 B0,IC0_CA2 , 1 , 19 ,2457,2457, 0, 9 B0,IC0_CA3 , 1 , 18 ,2457,2457, 0, 9 B0,IC0_CA4 , 1 , 37 ,2457,2457, 0, 9 B0,IC0_CA5 , 1 , 38 ,2457,2457, 0, 9 B0,IC0_CA6 , 1 , 22 ,2457,2457, 0, 9 B0,IC0_CA7 , 1 , 16 ,2457,2457, 0, 9 B0,IC0_CA8 , 1 , 16 ,2457,2457, 0, 9 B0,IC0_CABI, 1 , 24 ,2457,2457, 0, 9 B0,IC0_CA9 , 1 , 19 ,2457,2457, 0, 9 B0,IC1_CA0 , 1 , 13 ,2457,2457, 0, 9 B0,IC1_CA1 , 1 , 37 ,2457,2457, 0, 9 B0,IC1_CA2 , 1 , 30 ,2457,2457, 0, 9 B0,IC1_CA3 , 1 , 35 ,2457,2457, 0, 9 B0,IC1_CA4 , 1 , 25 ,2457,2457, 0, 9 B0,IC1_CA5 , 1 , 41 ,2457,2457, 0, 9 B0,IC1_CA6 , 1 , 34 ,2457,2457, 0, 9 B0,IC1_CA7 , 1 , 34 ,2457,2457, 0, 9 B0,IC1_CA8 , 1 , 31 ,2457,2457, 0, 9 B0,IC1_CABI, 1 , 28 ,2457,2457, 0, 9 B0,IC1_CA9 , 1 , 25 ,2457,2457, 0, 9 B1,IC0_CA0 , 1 , 26 ,2457,2457, 0, 9 B1,IC0_CA1 , 1 , 37 ,2457,2457, 0, 9 B1,IC0_CA2 , 1 , 33 ,2457,2457, 0, 9 B1,IC0_CA3 , 1 , 36 ,2457,2457, 0, 9 B1,IC0_CA4 , 1 , 21 ,2457,2457, 0, 9 B1,IC0_CA5 , 1 , 39 ,2457,2457, 0, 9 B1,IC0_CA6 , 1 , 39 ,2457,2457, 0, 9 B1,IC0_CA7 , 1 , 26 ,2457,2457, 0, 9 B1,IC0_CA8 , 1 , 12 ,2457,2457, 0, 9 B1,IC0_CABI, 1 , 24 ,2457,2457, 0, 9 B1,IC0_CA9 , 1 , 14 ,2457,2457, 0, 9 B1,IC1_CA0 , 1 , 18 ,2457,2457, 0, 9 B1,IC1_CA1 , 1 , 35 ,2457,2457, 0, 9 B1,IC1_CA2 , 1 , 18 ,2457,2457, 0, 9 B1,IC1_CA3 , 1 , 31 ,2457,2457, 0, 9 B1,IC1_CA4 , 1 , 32 ,2457,2457, 0, 9 B1,IC1_CA5 , 1 , 37 ,2457,2457, 0, 9 B1,IC1_CA6 , 1 , 20 ,2457,2457, 0, 9 B1,IC1_CA7 , 1 , 26 ,2457,2457, 0, 9 B1,IC1_CA8 , 1 , 13 ,2457,2457, 0, 9 B1,IC1_CABI, 1 , 21 ,2457,2457, 0, 9 B1,IC1_CA9 , 1 , 8 ,2457,2457, 0, 9 C0,IC0_CA0 , 1 , 27 , 273, 273, 0, 1 C0,IC0_CA1 , 1 , 19 , 273, 273, 0, 1 C0,IC0_CA2 , 1 , 34 , 273, 273, 0, 1 C0,IC0_CA3 , 1 , 4 ,2457,2457, 0, 9 C0,IC0_CA4 , 1 , 27 , 273, 273, 0, 1 C0,IC0_CA5 , 1 , 35 , 273, 273, 0, 1 C0,IC0_CA6 , 1 , 15 , 273, 273, 0, 1 C0,IC0_CA7 , 1 , 7 ,2457,2457, 0, 9 C0,IC0_CA8 , 3 , 63 , 273, 273, 0, 1 C0,IC0_CABI, 3 , 63 , 273, 273, 0, 1 C0,IC0_CA9 , 3 , 63 , 273, 273, 0, 1 C0,IC1_CA0 , 1 , 37 , 273, 273, 0, 1 C0,IC1_CA1 , 1 , 34 , 273, 273, 0, 1 C0,IC1_CA2 , 1 , 30 , 273, 273, 0, 1 C0,IC1_CA3 , 1 , 23 ,2457,2457, 0, 9 C0,IC1_CA4 , 1 , 48 , 273, 273, 0, 1 C0,IC1_CA5 , 1 , 30 , 273, 273, 0, 1 C0,IC1_CA6 , 1 , 15 , 273, 273, 0, 1 C0,IC1_CA7 , 1 , 26 ,2457,2457, 0, 9 C0,IC1_CA8 , 1 , 35 , 273, 273, 0, 1 C0,IC1_CABI, 1 , 40 , 273, 273, 0, 1 C0,IC1_CA9 , 1 , 37 , 273, 273, 0, 1 C1,IC0_CA0 , 1 , 44 ,2457,2457, 0, 9 C1,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 C1,IC0_CA2 , 1 , 33 ,2457,2457, 0, 9 C1,IC0_CA3 , 1 , 27 , 0, 0, 0, 0 C1,IC0_CA4 , 1 , 36 ,2457,2457, 0, 9 C1,IC0_CA5 , 1 , 32 ,2457,2457, 0, 9 C1,IC0_CA6 , 1 , 22 ,2457,2457, 0, 9 C1,IC0_CA7 , 1 , 14 , 0, 0, 0, 0 C1,IC0_CA8 , 1 , 29 ,2457,2457, 0, 9 C1,IC0_CABI, 1 , 35 ,2457,2457, 0, 9 C1,IC0_CA9 , 1 , 42 ,2457,2457, 0, 9 C1,IC1_CA0 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA1 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA2 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA3 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA4 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA5 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA6 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA7 , 3 , 63 , 0, 0, 0, 0 C1,IC1_CA8 , 3 , 63 ,2457,2457, 0, 9 C1,IC1_CABI, 3 , 63 ,2457,2457, 0, 9 C1,IC1_CA9 , 3 , 63 ,2457,2457, 0, 9 D0,IC0_CA0 , 1 , 16 ,2457,2457, 0, 9 D0,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 D0,IC0_CA2 , 1 , 27 ,2457,2457, 0, 9 D0,IC0_CA3 , 1 , 13 ,2457,2457, 0, 9 D0,IC0_CA4 , 1 , 17 ,2457,2457, 0, 9 D0,IC0_CA5 , 1 , 33 ,2457,2457, 0, 9 D0,IC0_CA6 , 1 , 20 ,2457,2457, 0, 9 D0,IC0_CA7 , 1 , 14 ,2457,2457, 0, 9 D0,IC0_CA8 , 1 , 2 ,2457,2457, 0, 9 D0,IC0_CABI, 1 , 21 ,2457,2457, 0, 9 D0,IC0_CA9 , 1 , 12 ,2457,2457, 0, 9 D0,IC1_CA0 , 1 , 28 ,2457,2457, 0, 9 D0,IC1_CA1 , 1 , 22 ,2457,2457, 0, 9 D0,IC1_CA2 , 1 , 22 ,2457,2457, 0, 9 D0,IC1_CA3 , 1 , 30 ,2457,2457, 0, 9 D0,IC1_CA4 , 1 , 27 ,2457,2457, 0, 9 D0,IC1_CA5 , 1 , 32 ,2457,2457, 0, 9 D0,IC1_CA6 , 1 , 33 ,2457,2457, 0, 9 D0,IC1_CA7 , 1 , 28 ,2457,2457, 0, 9 D0,IC1_CA8 , 1 , 14 ,2457,2457, 0, 9 D0,IC1_CABI, 1 , 35 ,2457,2457, 0, 9 D0,IC1_CA9 , 1 , 16 ,2457,2457, 0, 9 D1,IC0_CA0 , 1 , 27 ,2457,2457, 0, 9 D1,IC0_CA1 , 1 , 20 ,2457,2457, 0, 9 D1,IC0_CA2 , 1 , 27 ,2457,2457, 0, 9 D1,IC0_CA3 , 1 , 16 ,2457,2457, 0, 9 D1,IC0_CA4 , 1 , 31 ,2457,2457, 0, 9 D1,IC0_CA5 , 1 , 13 ,2457,2457, 0, 9 D1,IC0_CA6 , 1 , 16 ,2457,2457, 0, 9 D1,IC0_CA7 , 1 , 29 ,2457,2457, 0, 9 D1,IC0_CA8 , 1 , 13 ,2457,2457, 0, 9 D1,IC0_CABI, 1 , 30 ,2457,2457, 0, 9 D1,IC0_CA9 , 1 , 28 ,2457,2457, 0, 9 D1,IC1_CA0 , 1 , 15 ,2457,2457, 0, 9 D1,IC1_CA1 , 1 , 29 ,2457,2457, 0, 9 D1,IC1_CA2 , 1 , 15 ,2457,2457, 0, 9 D1,IC1_CA3 , 1 , 9 ,2457,2457, 0, 9 D1,IC1_CA4 , 1 , 25 ,2457,2457, 0, 9 D1,IC1_CA5 , 1 , 33 ,2457,2457, 0, 9 D1,IC1_CA6 , 1 , 13 ,2457,2457, 0, 9 D1,IC1_CA7 , 1 , 21 ,2457,2457, 0, 9 D1,IC1_CA8 , 1 , 14 ,2457,2457, 0, 9 D1,IC1_CABI, 1 , 20 ,2457,2457, 0, 9 D1,IC1_CA9 , 1 , 16 ,2457,2457, 0, 9 E0,IC0_CA0 , 1 , 28 ,2457,2457, 0, 9 E0,IC0_CA1 , 1 , 25 ,2457,2457, 0, 9 E0,IC0_CA2 , 1 , 24 ,2457,2457, 0, 9 E0,IC0_CA3 , 1 , 40 ,2457,2457, 0, 9 E0,IC0_CA4 , 1 , 41 ,2457,2457, 0, 9 E0,IC0_CA5 , 1 , 43 ,2457,2457, 0, 9 E0,IC0_CA6 , 1 , 43 ,2457,2457, 0, 9 E0,IC0_CA7 , 1 , 28 ,2457,2457, 0, 9 E0,IC0_CA8 , 1 , 26 ,2457,2457, 0, 9 E0,IC0_CABI, 1 , 24 ,2457,2457, 0, 9 E0,IC0_CA9 , 1 , 29 ,2457,2457, 0, 9 E0,IC1_CA0 , 1 , 19 ,2457,2457, 0, 9 E0,IC1_CA1 , 1 , 26 ,2457,2457, 0, 9 E0,IC1_CA2 , 1 , 38 ,2457,2457, 0, 9 E0,IC1_CA3 , 1 , 37 ,2457,2457, 0, 9 E0,IC1_CA4 , 1 , 23 ,2457,2457, 0, 9 E0,IC1_CA5 , 1 , 49 ,2457,2457, 0, 9 E0,IC1_CA6 , 1 , 31 ,2457,2457, 0, 9 E0,IC1_CA7 , 1 , 32 ,2457,2457, 0, 9 E0,IC1_CA8 , 1 , 36 ,2457,2457, 0, 9 E0,IC1_CABI, 1 , 30 ,2457,2457, 0, 9 E0,IC1_CA9 , 1 , 32 ,2457,2457, 0, 9 E1,IC0_CA0 , 1 , 26 ,2457,2457, 0, 9 E1,IC0_CA1 , 1 , 21 ,2457,2457, 0, 9 E1,IC0_CA2 , 1 , 8 ,2457,2457, 0, 9 E1,IC0_CA3 , 1 , 34 ,2457,2457, 0, 9 E1,IC0_CA4 , 1 , 24 ,2457,2457, 0, 9 E1,IC0_CA5 , 1 , 31 ,2457,2457, 0, 9 E1,IC0_CA6 , 1 , 25 ,2457,2457, 0, 9 E1,IC0_CA7 , 1 , 18 ,2457,2457, 0, 9 E1,IC0_CA8 , 1 , 13 ,2457,2457, 0, 9 E1,IC0_CABI, 1 , 31 ,2457,2457, 0, 9 E1,IC0_CA9 , 1 , 3 ,2457,2457, 0, 9 E1,IC1_CA0 , 1 , 9 ,2457,2457, 0, 9 E1,IC1_CA1 , 1 , 25 ,2457,2457, 0, 9 E1,IC1_CA2 , 1 , 23 ,2457,2457, 0, 9 E1,IC1_CA3 , 1 , 26 ,2457,2457, 0, 9 E1,IC1_CA4 , 1 , 30 ,2457,2457, 0, 9 E1,IC1_CA5 , 1 , 28 ,2457,2457, 0, 9 E1,IC1_CA6 , 1 , 23 ,2457,2457, 0, 9 E1,IC1_CA7 , 1 , 17 ,2457,2457, 0, 9 E1,IC1_CA8 , 1 , 9 ,2457,2457, 0, 9 E1,IC1_CABI, 1 , 34 ,2457,2457, 0, 9 E1,IC1_CA9 , 1 , 12 ,2457,2457, 0, 9 F0,IC0_CA0 , 1 , 15 ,2457,2457, 0, 9 F0,IC0_CA1 , 1 , 19 ,2457,2457, 0, 9 F0,IC0_CA2 , 1 , 19 ,2457,2457, 0, 9 F0,IC0_CA3 , 1 , 36 ,2457,2457, 0, 9 F0,IC0_CA4 , 1 , 34 ,2457,2457, 0, 9 F0,IC0_CA5 , 1 , 24 ,2457,2457, 0, 9 F0,IC0_CA6 , 1 , 36 ,2457,2457, 0, 9 F0,IC0_CA7 , 1 , 20 ,2457,2457, 0, 9 F0,IC0_CA8 , 1 , 8 ,2457,2457, 0, 9 F0,IC0_CABI, 1 , 23 ,2457,2457, 0, 9 F0,IC0_CA9 , 1 , 11 ,2457,2457, 0, 9 F0,IC1_CA0 , 1 , 27 ,2457,2457, 0, 9 F0,IC1_CA1 , 1 , 42 ,2457,2457, 0, 9 F0,IC1_CA2 , 1 , 27 ,2457,2457, 0, 9 F0,IC1_CA3 , 1 , 38 ,2457,2457, 0, 9 F0,IC1_CA4 , 1 , 25 ,2457,2457, 0, 9 F0,IC1_CA5 , 1 , 43 ,2457,2457, 0, 9 F0,IC1_CA6 , 1 , 24 ,2457,2457, 0, 9 F0,IC1_CA7 , 1 , 23 ,2457,2457, 0, 9 F0,IC1_CA8 , 1 , 16 ,2457,2457, 0, 9 F0,IC1_CABI, 1 , 25 ,2457,2457, 0, 9 F0,IC1_CA9 , 1 , 25 ,2457,2457, 0, 9 F1,IC0_CA0 , 1 , 40 ,2457,2457, 0, 9 F1,IC0_CA1 , 1 , 43 ,2457,2457, 0, 9 F1,IC0_CA2 , 1 , 53 ,2457,2457, 0, 9 F1,IC0_CA3 , 1 , 22 ,2457,2457, 0, 9 F1,IC0_CA4 , 1 , 42 ,2457,2457, 0, 9 F1,IC0_CA5 , 1 , 30 ,2457,2457, 0, 9 F1,IC0_CA6 , 1 , 23 ,2457,2457, 0, 9 F1,IC0_CA7 , 1 , 29 ,2457,2457, 0, 9 F1,IC0_CA8 , 1 , 34 ,2457,2457, 0, 9 F1,IC0_CABI, 1 , 51 ,2457,2457, 0, 9 F1,IC0_CA9 , 1 , 44 ,2457,2457, 0, 9 F1,IC1_CA0 , 1 , 43 ,2457,2457, 0, 9 F1,IC1_CA1 , 1 , 25 ,2457,2457, 0, 9 F1,IC1_CA2 , 1 , 30 ,2457,2457, 0, 9 F1,IC1_CA3 , 1 , 16 ,2457,2457, 0, 9 F1,IC1_CA4 , 1 , 37 ,2457,2457, 0, 9 F1,IC1_CA5 , 1 , 32 ,2457,2457, 0, 9 F1,IC1_CA6 , 1 , 31 ,2457,2457, 0, 9 F1,IC1_CA7 , 1 , 27 ,2457,2457, 0, 9 F1,IC1_CA8 , 1 , 40 ,2457,2457, 0, 9 F1,IC1_CABI, 1 , 37 ,2457,2457, 0, 9 F1,IC1_CA9 , 1 , 44 ,2457,2457, 0, 9
WCK2CK Training Status: PA,SIGNAL,DLY,Last Early,First Late,Delta A ,WCK01 , 0, 153 , 153 , 0 A ,WCKB01, 0, 153 , 153 , 0 A ,WCK23 , 0, 153 , 153 , 0 A ,WCKB23, 0, 153 , 153 , 0 A ,WCK45 , 0, 153 , 153 , 0 A ,WCKB45, 0, 153 , 153 , 0 A ,WCK67 , 0, 153 , 153 , 0 A ,WCKB67, 0, 153 , 153 , 0 B ,WCK01 , 0, 153 , 153 , 0 B ,WCKB01, 0, 153 , 153 , 0 B ,WCK23 , 0, 153 , 153 , 0 B ,WCKB23, 0, 153 , 153 , 0 B ,WCK45 , 0, 153 , 153 , 0 B ,WCKB45, 0, 153 , 153 , 0 B ,WCK67 , 0, 153 , 153 , 0 B ,WCKB67, 0, 153 , 153 , 0 C ,WCK01 , 0, 17 , 17 , 0 C ,WCKB01, 0, 17 , 17 , 0 C ,WCK23 , 0, 17 , 17 , 0 C ,WCKB23, 0, 153 , 153 , 0 C ,WCK45 , 0, 153 , 153 , 0 C ,WCKB45, 0, 153 , 153 , 0 C ,WCK67 , 0, 153 , 153 , 0 C ,WCKB67, 0, 0 , 0 , 0 D ,WCK01 , 0, 153 , 153 , 0 D ,WCKB01, 0, 153 , 153 , 0 D ,WCK23 , 0, 153 , 153 , 0 D ,WCKB23, 0, 153 , 153 , 0 D ,WCK45 , 0, 153 , 153 , 0 D ,WCKB45, 0, 153 , 153 , 0 D ,WCK67 , 0, 153 , 153 , 0 D ,WCKB67, 0, 153 , 153 , 0 E ,WCK01 , 0, 153 , 153 , 0 E ,WCKB01, 0, 153 , 153 , 0 E ,WCK23 , 0, 153 , 153 , 0 E ,WCKB23, 0, 153 , 153 , 0 E ,WCK45 , 0, 153 , 153 , 0 E ,WCKB45, 0, 153 , 153 , 0 E ,WCK67 , 0, 153 , 153 , 0 E ,WCKB67, 0, 153 , 153 , 0 F ,WCK01 , 0, 153 , 153 , 0 F ,WCKB01, 0, 153 , 153 , 0 F ,WCK23 , 0, 153 , 153 , 0 F ,WCKB23, 0, 153 , 153 , 0 F ,WCK45 , 0, 153 , 153 , 0 F ,WCKB45, 0, 153 , 153 , 0 F ,WCK67 , 0, 153 , 153 , 0 F ,WCKB67, 0, 153 , 153 , 0
READ Training Status: ,PA,PAD ,BS,IPL,MIN,MAX,PASS,WIN IB ,A0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,A0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,A1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,B0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,B1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ00,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ01,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ02,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ04,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ05,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ06,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI0,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ08,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ09,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ10,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ12,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ13,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ14,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI1,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ16,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ17,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ18,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ20,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ21,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ22,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI2,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ24,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ25,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ26,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DQ28,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ29,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ30,29, 0, 273, 273, 1,1,*** Warning **** IB ,C0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,C0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ35,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ39,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ43,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ47,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ51,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ55,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ59,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,C1,DQ63,29, 0, 0, 0, 1,0,*** Fail **** IB ,C1,DBI7,29, 0, 0, 0, 1,0,*** Fail **** IB ,D0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,D0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,D1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,E0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,E1,DBI7,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ00,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ01,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ02,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ03,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ04,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ05,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ06,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ07,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI0,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ08,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ09,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ10,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ11,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ12,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ13,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ14,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ15,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI1,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ16,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ17,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ18,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ19,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ20,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ21,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ22,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ23,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI2,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ24,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ25,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ26,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ27,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ28,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ29,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ30,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DQ31,29, 0,2457,2457, 1,9,*** Warning **** IB ,F0,DBI3,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ32,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ33,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ34,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ35,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ36,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ37,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ38,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ39,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI4,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ40,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ41,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ42,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ43,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ44,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ45,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ46,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ47,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI5,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ48,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ49,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ50,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ51,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ52,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ53,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ54,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ55,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI6,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ56,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ57,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ58,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ59,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ60,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ61,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ62,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DQ63,29, 0,2457,2457, 1,9,*** Warning **** IB ,F1,DBI7,29, 0,2457,2457, 1,9,*** Warning ****
WRITE Training Status: ,PA,PAD ,BS,IPL,MIN,MAX,PAS,WIN OB ,A0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,A0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,A1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,B0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,B1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ00, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ01, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ02, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ03, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ04, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ05, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ06, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ07, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI0, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ08, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ09, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ10, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ11, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ12, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ13, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ14, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ15, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI1, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ16,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ17,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ18,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ20,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ21,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ22,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI2,11, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ24, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ25, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ26, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ27, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DQ28, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ29, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ30, 3, 0, 273, 273, 1,1,*** Warning **** OB ,C0,DQ31, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C0,DBI3, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ32, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ33, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ34, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ35, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ36, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ37, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ38, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ39, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DBI4, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ43,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ47,11, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ48, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ49, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ50, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ51, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ52, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ53, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ54, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ55, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DBI6, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ56, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ57, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ58, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ59, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DQ60, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ61, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ62, 3, 0,2457,2457, 1,9,*** Warning **** OB ,C1,DQ63, 3, 0, 0, 0, 1,0,*** Fail **** OB ,C1,DBI7, 3, 0, 0, 0, 1,0,*** Fail **** OB ,D0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,D0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,D1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ00, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ01, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ02, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ03, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ04, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ05, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ06, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ07, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI0, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ08, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ09, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ10, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ11, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ12, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ13, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ14, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ15, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI1, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ16, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ17, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ18, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ19, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ20, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ21, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ22, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ23, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI2, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,E0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ40, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ41, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ42, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ43, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ44, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ45, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ46, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ47, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI5, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ48, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ49, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ50, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ51, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ52, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ53, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ54, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ55, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI6, 3, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,E1,DBI7,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ00,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ01,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ02,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ03,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ04,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ05,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ06,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ07,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI0,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ08,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ09,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ10,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ11,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ12,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ13,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ14,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ15,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI1,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ16,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ17,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ18,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ19,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ20,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ21,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ22,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ23,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI2,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ24,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ25,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ26,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ27,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ28,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ29,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ30,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DQ31,11, 0,2457,2457, 1,9,*** Warning **** OB ,F0,DBI3,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ32,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ33,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ34,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ35,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ36,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ37,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ38,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ39,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI4,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ40,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ41,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ42,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ43,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ44,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ45,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ46,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ47,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI5,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ48,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ49,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ50,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ51,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ52,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ53,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ54,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ55,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI6,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ56,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ57,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ58,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ59,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ60,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ61,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ62,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DQ63,11, 0,2457,2457, 1,9,*** Warning **** OB ,F1,DBI7,11, 0,2457,2457, 1,9,*** Warning ****
CLKM = 9752.00 MHz; GDDR6X MODE 1 Command Mapping: SUBP0 | SUBP1 , A0, A1, B0, B1, C0, C1, D0, D1, E0, E1, F0, F1 PAD00:CA8A|PAD28:CA8B,111,118, 80, 77,255,255, 66, 78, 90, 73, 72,104 PAD01:CA0A|PAD29:CA0B,109,117, 67, 82, 91,255, 80, 79, 92, 73, 79,107 PAD02:CA9A|PAD30:CA9B,117,116, 83, 72,255,255, 76, 80, 93, 76, 75,108 PAD03:RST*|PAD31:RST*, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64 PAD04:CA9B|PAD32:CA9A,116,103, 89, 78,101,106, 80, 92, 96, 67, 89,108 PAD05:CA0B|PAD33:CA0A,119,115, 77, 90,101,108, 92, 91, 83, 90, 91,104 PAD06:CA8B|PAD34:CA8A,106, 95, 95, 76, 99, 93, 78, 77,100, 77, 80, 98 PAD07:CA4B|PAD35:CA2A,125, 96, 89, 97,112, 97, 91, 91, 87, 72, 89,117 PAD08:CA2B|PAD36:CA4A,122,108, 94, 85, 94,100, 86, 95,102, 88, 91,106 PAD09:ABIB|PAD37:ABIA,112, 95, 92, 88,104, 99, 99, 94, 94, 95, 89,115 PAD10:ABIA|PAD38:ABIB,108,101, 88, 85,255,255, 85, 84, 88, 98, 87,101 PAD11:CA2A|PAD39:CA4B,105,102, 83, 96, 98,255, 91, 89, 88, 94, 83,101 PAD12:CA4A|PAD40:CA2B,105, 97,101, 82, 91,255, 81, 79,105, 87, 98, 94 PAD13:CKEA|PAD41:CKEB, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64 PAD14:CA1A|PAD42:CA5B,102, 96, 95,101, 83,255, 89, 97, 89, 92, 83, 96 PAD15:CA5A|PAD43:CA1B,103, 91,102, 99, 99,255, 97, 93,107, 89, 88, 89 PAD16:CA5B|PAD44:CA1A,113, 92,105,101, 94, 89, 96, 84,113, 85,107,107 PAD17:CA1B|PAD45:CA5A,104, 99,101,103, 98, 96, 86, 77, 90, 95,106, 94 PAD18:CKEB|PAD46:CEKA, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64 PAD19:CA7B|PAD47:CA3A,102, 79, 98,100, 90, 91, 92, 80, 96, 98, 87, 86 PAD20:CA3B|PAD48:CA7A, 99, 75, 99, 90, 87, 78, 94, 93,101, 82,102, 93 PAD21:CA6B|PAD49:CA6A, 88, 75, 98,103, 79, 86, 97, 80, 95, 89, 88, 87 PAD22:CA6A|PAD50:CA6B, 93, 72, 86, 84, 79,255, 84, 77,107, 87,100, 95 PAD23:CA7A|PAD51:CA3B, 79, 71, 80, 95, 71,255, 78, 73, 92, 90, 84, 80 PAD24:CA3A|PAD52:CA7B, 79, 72, 82, 90, 68,255, 77, 85,104, 81,100, 91
