RTx 3060 Asus CUDAL2Mats keeps failing https://vlab.su/viewtopic.php?f=48&t=135010 |
dowhile [ 26 май 2023, 11:49 ] | |
Заголовок сообщения: | RTx 3060 Asus CUDAL2Mats keeps failing |
Hi guys, just discovered these forum and you russians are great.. i work here in italy as electronic repair and i wanna ask you if this card can be saved or the gpu is dead... Cudal2mats keeps failing... Card works in low resolution but after driver installation keeps freezing and then crash... this is the screen.. i ve already tried a different mainboard and different versions of MATS MODS, 455.127 455.120_3060 but still the same... memory is working. vram test is ok. phase Coils are switching at 300Khz. Thanks |
azzed [ 29 май 2023, 01:03 ] | |
Заголовок сообщения: | Re: RTx 3060 Asus CUDAL2Mats keeps failing |
gpu reballing |
