Текущее время: 03 май 2024, 23:07
Dance0fArrows
Заголовок сообщения: Gainward RTX3070 only works with AMD Mainboard/CPU Добавлено: 07 сен 2023, 18:52 |
Зарегистрирован: 30 дек 2022, 20:59 Наличности на руках: 13.02
Сообщения: 7 Откуда: Germany
Hello,
Ive got a serious case. My RTX3070 from Gainward works perfectly in my AMD PC, no problems at all. As soon as this is plugged into an Intel PC (i3 11th gen), it is no longer recognized and of course does not output an image. This is not recognized in MODS either. This doesn't work on another Intel PC either. Other graphics cards work perfectly in the PCs. All voltages are present, no short circuits. I also tried all other display outputs, with no result.
There is a known problem for which there was a BIOS update, which I also installed, unfortunately without changing it. Have also changed the PCIE generation several times, without improvement.
The only thing I noticed was that the HDMI output was swapped for a shorter one. In addition, two memories were probably replaced. BIOS version: 94.04.3A.40.85
I hope someone could help me there.
pLeXz
Заголовок сообщения: Re: Gainward RTX3070 only works with AMD Mainboard/CPU Добавлено: 08 сен 2023, 13:11 |
Зарегистрирован: 16 июн 2023, 23:08 Наличности на руках: 29.00
Сообщения: 22 Откуда: 2la
Dance0fArrows писал(а): If the intel only recognizes 8 lanes, then it still has to be recognized, right? Intel platform recognize from first pci-e line, if its broken - card wont start. AMD platform work different and will recognize card even if first pci-e line doesnt work. Try to measure voltage drop on pci-e pairs from 1 to 6-8. They must be exact same. If first pair is fail - intel platform wont work. In that case solution will be replacing first pair by second. Usualy that happens with issue from pci-e riser.
jeffersonsilva998
Заголовок сообщения: Re: Gainward RTX3070 only works with AMD Mainboard/CPU Добавлено: 09 сен 2023, 02:35 |
Зарегистрирован: 12 янв 2022, 23:43 Наличности на руках: 18.13
Сообщения: 47 Откуда: brazil
Dance0fArrows писал(а): Cometi um erro… então primeiro: medi as pistas no modo diodo. fiz como cemitério de tecnologia no youtube. Não sei se existem melhores. A princípio pensei que os 2,7V no primeiro pino eram anormais, mas tudo bem. então notei o primeiro par, ou seja, o 3º e o 4º pinos. O pino 3 estava “aberto” e o pino 4 estava em 1,6V. 1,6 V deve servir, já que todo mundo também tem 1,6 V. mas o pino 3 provavelmente está frito. Eu conectei os pinos 3 e 4. Infelizmente isso não ajudou :( o que eu fiz de errado проводом соскоблить поврежденную/разомкнутую дорожку с pciexpres 1x и кинуть на GND, в некоторых случаях карта начинает нормально распознавать 1x только с половины волны сигнала.
