Текущее время: 03 май 2024, 05:16
azzed
Заголовок сообщения: RTX 3070 ZOTAC, DRMOS DAMAGED, PROBLEM PERSISTS AFTER 5 DAYS Добавлено: 05 окт 2023, 18:35 |
Зарегистрирован: 09 июл 2022, 08:06 Наличности на руках: 32.00
Сообщения: 44 Откуда: lima-Perú
Hello friends, I repair video cards for a living, I have a problem with an RTX 3070 ZOTAC GAMING, this card uses (up9512r) and drmosfet (AOZ5311NQI BLN0). The problem is that when you replace the damaged mosfet, the board works properly for 3 to 5 days, then another mosfet fails again, can you help me, what can I do? THANKS YOU
