Текущее время: 24 апр 2024, 00:23
lungkao
Заголовок сообщения: Re: VGA port Добавлено: 08 мар 2014, 06:00 |
Зарегистрирован: 06 мар 2014, 22:31 Наличности на руках: 13.00
Сообщения: 6 Откуда: usa
CRImier писал(а): Hello! Unfortunately, you can't do that because signal type on VGA port and on LCD panel are different. It seems that to make it work you only can fix what's broken on each laptop. What could be broken? I have a few suggestions.
1) Panel - the part of it that shows the image on the screen or, maybe, the matrix itself. 2) Backlight of the panel, that makes the image visible. Could be lamps or LED. 3) Invertor - the circuit that powers the backlight. 4) Cable between the panel and motherboard. 5) Cable between the invertor and motherboard 6) Some little components and connectors on the motherboard 7) Video chip on the motherboard
For each of these laptops you can have a different problem, so you have to check every one of them. ----------- thank you for your infomation
tsurik
Заголовок сообщения: Re: VGA port Добавлено: 08 мар 2014, 12:32 |
Зарегистрирован: 29 мар 2013, 19:44 Наличности на руках: 1,110.22
Сообщения: 378 Откуда: Украина Николаев
ayad писал(а): Hi all , some times there are many laptops can not show anything on their display panel , but when I connect external display using vga port , they work will , so could I connect that port to display panel using simple circuit and thanks so much.......... You can use universal display scaler like this http://m.aliexpress.com/item-desc/1625909134.html
