Hi Russian friends, I need you to help me do little hack on this Quadro card.
Basically, I got MSI laptop, 2nd gen Intel, MS-1761 motherboard. Laptop originally came with 570m which died. I tried replace it with Quadro 3000m but laptop would not POST (this model works only on dedicated card).
So I flashed VBIOS to 675m which resulted in passing POST but I couldn't install driver for it (maybe I could modify Quadro driver, but I wanted to change it to GTX).
Now what I need is to locate Devide ID resistors (configuration straps) to recognize it as 675m. I already checked half of board but still didn't located anything. I marked on pictures what I tried but those resistors are pretty much the same on both boards. PCBs are not same revision which complicates it a bit. I uploaded picture of 570m as well because that board is marked, that picture is just for reference.
If you have similar board please help, give me some suggestion on this :)
Thanks!
675m&Quadro 3000m front:
675m&Quadro 3000m back:
570m:
Recognized Device ID:
