Заголовок сообщения: Shappire 5870 1GB power cutoff after few second.
Добавлено: 02 окт 2018, 20:20
Зарегистрирован: 21 июл 2018, 10:32 Наличности на руках: 57.41 Сообщения: 39 Откуда: England
Hello all,
I hope that I will get help again. I have problem with Radeon 5870 1GB from Sapphire company.
The problem is with temperatures. When I tested this card I noticed that under 50 degrees card works perfectly. However if temp grow above 50 degrees then it restart the computer. Moreover I set fan speed on the 100% and I run stress test with "furmark". The graphic card worked about 30-50s before it had reached a 50 degrees and restart the computer.
Could you give me some Tip what I should to check or something like that.
Can it be dependent on thermistor?
alex4
Заголовок сообщения: Re: Shappire 5870 1GB power cutoff after few second.
Добавлено: 04 окт 2018, 21:31
Зарегистрирован: 04 мар 2018, 22:51 Наличности на руках: 143.77 Сообщения: 136 Откуда: Astana
i think no, card dont have any thermistors
maybe VRM overheated, try to measure temperatures at some points on card
Micchaleq
Добавлено: 11 окт 2018, 19:05
Thank you for your answer. I made many testes and the problem was very easy. HD5870 have some protection aginst processor overheating or something like that. So without cooling system voltages desapears.
Сейчас этот форум просматривают: madking и гости: 16
