Текущее время: 24 апр 2024, 20:44
Micchaleq
Заголовок сообщения: Sapphire RX560 4GB - SHORT Добавлено: 22 ноя 2018, 19:12 |
Зарегистрирован: 21 июл 2018, 10:32 Наличности на руках: 57.41
Сообщения: 39 Откуда: England
Hi for everyone. I have problem with RX560 4GB. The problem is that I have shortcircuit and I can't find wrong component. Firstly I check fuse (front PCB and red square) it was broken but also there are shortcircuit (green arrow). I tried apply power supply with 4Amps and 12Volts and after connected on the power supply I have about 0.007Volts and 4Amps. I dont know why volts are that small. Moreover nothing going hot. After that I decided to lift up power section but the problem doesn't gone. Moreover I lifted up mosfet controller (RT8880C) where I have shortcircuit on enable. Futhermore I lifted up linear stabilizator where is short on the output site. On the second picture (back side of PCB) you can see area of controller and stabilizator and green arrow indicate shortcircuits. My question is how can I check GPU before I lift it up? (it is dead or not). What can I measure and how to diagnose it in the next steps. I can add that i have about 2 ohms on GPU (and i think that it is enough). I suppose that GPU is ok because the production date is 1703. Thank you for help.
Micchaleq
Заголовок сообщения: Re: Sapphire RX560 4GB - SHORT Добавлено: 23 ноя 2018, 00:33 |
gserg писал(а): I think that is the death of the mosfet in the power supply of the chip, in some of the phases to be detected is a low-power laboratory source fails, the faulty MOSFET needs to have a leak from the gate to the channel, check with a multimeter, good luck Thank you for answer. I have written that I lifted up whole power section and the volts doesn't grow up. Moreover shortcircuit still present without mosfets . Hovewer I will try to do it second time. I will remove every component if i have to. I will start from those bigger. On the other hands I have checked every mosfet (G-D, G-S, GND-G) and I had not any leak.
Micchaleq
Заголовок сообщения: Re: Sapphire RX560 4GB - SHORT Добавлено: 23 ноя 2018, 03:39 |
gserg писал(а): then there are the capacitors, remove the aluminum Yea that was it. One of aluminim capacitor was have about 50% capacity so I have replace it. However it wasn't main problem. SMD capacitor was broken. I have replace it. After that shortcircuit has gone. Unfortunetly before I had search near power section I take off GPU. Now I have to put it back and I will check if it is all or not.
Micchaleq
Заголовок сообщения: Re: Sapphire RX560 4GB - SHORT Добавлено: 23 ноя 2018, 13:46 |
Micchaleq писал(а): gserg писал(а): then there are the capacitors, remove the aluminum Yea that was it. One of aluminim capacitor had about 50% capacity so I replaced it. However it wasn't main problem. SMD capacitor was broken. After I had replaced it shortcircuit has gone. Unfortunetly before I had search near power section I take off GPU. Now I have to put it back and I will check if it is all or not.
Micchaleq
Заголовок сообщения: Re: Sapphire RX560 4GB - SHORT Добавлено: 26 ноя 2018, 20:41 |
galkinvv писал(а): No 12V leads are going directly to GPU, so even completely dead/burned GPU can't cause 12V short-circuit. I think that highest voltage coming directly to GPU may be 5v, since DVI uses 5V-leveled I2C. Thank you for answer. I haven't got much experience so every tip is very important for me. I will remember it. However I was desperate to learn and solve problem. Now the MDU1514 is broken (after I had replaced capacitor it broke).
