https://vlab.su/
Problem graphic card gtx10606PB (GeForce GTX 1060 6GB) PNY
https://vlab.su/viewtopic.php?f=48&t=83810
Страница 1 из 1
bokin021 [ 05 дек 2018, 15:08 ]
Заголовок сообщения:  Problem graphic card gtx10606PB (GeForce GTX 1060 6GB) PNY
I need shematic or board view ,because no 1.1v on GPU ,i check all fuse also mosfet no short and i notice that EN signal does not come on pin 4 on NCP81174..I cant find way out from where enable must come ..
kolyandex [ 05 дек 2018, 18:52 ]
Заголовок сообщения:  Re: Problem graphic card gtx10606PB (GeForce GTX 1060 6GB) PNY
Do you mean 1.1 volts on PCI-e controller (PEX_VDD) or on GPU (NVVDD)? Just GPU powered by 0.8 volts.
bokin021 [ 05 дек 2018, 19:11 ]
No I mean on GPU controller EN..Reason why is not 0.8v on gpu
Can i bay somewhere boardview for this graphic card?
kolyandex [ 06 дек 2018, 06:58 ]
NVVDD will appear after powering on 1.8 volts step down converter. Does 8 pin on BIOS have 1.8 volts?
bokin021 [ 06 дек 2018, 22:25 ]
No 0.3v on bios..
kolyandex [ 07 дек 2018, 04:58 ]
Here is the answer :a_g_a:
bokin021 [ 10 дек 2018, 18:43 ]
I check ,bios 1,8v I have it s mean I must find out from where coming en signal ,it will be difficult without schematic ..If with power supply I do 1v on enable ,maybe will come 0.8v on phase ?Or is dangers?
bokin021 [ 18 дек 2018, 21:13 ]
i found problem
Posted after 31 second:
it was small resistor damage
http://www.phpbb.com/
