Заголовок сообщения: MSI 970 gaming crash power mosfet after some time.
Добавлено: 13 дек 2018, 12:26
Зарегистрирован: 21 июл 2018, 10:32 Наличности на руках: 57.41 Сообщения: 39 Откуда: England
Hi all,
I have problem with GTX 970 gaming. When this card come to me I have checked a shorts in power section. One of mosfet was in short. After I take it off on the gate wasn't short so i just place new one. After that card works fine I played games and so one, however maybe after 10 hours computer turn off and the same mosfet was broken.
That is abnormal do I have to know what is the problem. What lead to breaking the same mosfet.
kolyandex
Заголовок сообщения: Re: MSI 970 gaming crash power mosfet after some time.
Добавлено: 13 дек 2018, 18:55
Зарегистрирован: 11 ноя 2015, 09:19 Наличности на руках: 106.08 Сообщения: 192 Откуда: Новосибирск
You need replace also mosfets driver on the back of pcb. Small square ic.
Micchaleq
Добавлено: 14 дек 2018, 01:55
Thank you for answer you mean mosfet driver. There are ncp81162 and ncp81061. Both of them or just mosfet driver (81061)?
kolyandex
Добавлено: 14 дек 2018, 15:11
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 17
