gigabyte gtx1060 core clock stuck at 139 MHz https://vlab.su/viewtopic.php?f=48&t=85894 |
Raydel87 [ 30 янв 2019, 02:48 ] | |
Заголовок сообщения: | gigabyte gtx1060 core clock stuck at 139 MHz |
Hi, I have a Gigabyte GV-N1060WF2OC-3GD The issue is that the core clock is stuck at 139mhz. It seems that the GPU is locked on a low consumption power state. The closest schematic I have is from a gigabyte GTX-760. I have measure some GPIO signals near the INA3221 that are supposed to cause that, but there are in a high level. I'm a little frustated cause I don't have a more similar schematic, nor the GPU BGA layout. Any help will be appreciated. |
kolyandex [ 30 янв 2019, 07:13 ] | |
Заголовок сообщения: | Re: gigabyte gtx1060 core clock stuck at 139 MHz |
Hi. You shure in BIOS on this card? Try flash it from official site and be carefully to choose version (F0, F1, F2 e.g.) |
Raydel87 [ 30 янв 2019, 22:09 ] | |
I already did, I think is the GPIO12_LOW_PERF* signal, but I don't have the actual schematic from gigabyte. Now I have one schematic of the GTX1080 from ASUS that I'm using as reference; I think the BGA layout is the same that on the 1060. Thanks for he advice, anyway. |
