Текущее время: 09 май 2024, 09:40
 Заголовок сообщения: Gigabyte GTX 960 - computer can't start, stop on "2b" post code
СообщениеДобавлено: 10 июн 2019, 17:34
Hi all,
You helped me in the previous topics so I hope this time you can help me too.
I have problem with Gigabyte GTX 960. Тhe card has power for gpu , power for memory and other ones (3,3 , 5). I checked shorts but not present.
When I received card I replace two 0ohm resistors to bios chips. They were broken.
Now when I try to turn on PC I can see 2b code on the POST card and it freeze. The power is still present.
I think that it have to be something with bioses, however I reflashed them and it didn't help.
What could broke those 0ohm resistors? What should I check?
ThePCB looks like this:
https://img.hexus.net/v2/graphics_cards ... 0WF-2b.png
https://www.vortez.net/contentteller.ph ... e&id=29336
Here is the place where are 0ohm
https://www.modders-inc.com/wp-content/ ... g1bios.jpg
Last question, which component is responsible for switching bioses?
Is this one marked as U20?
 Заголовок сообщения: Re: Gigabyte GTX 960 - computer can't start, stop on "2b" post code
СообщениеДобавлено: 10 июн 2019, 23:18
check voltage this cirсuit
СообщениеДобавлено: 18 июн 2019, 00:40
Voltages looks good around bioses (1,3,6,7,8 = 3.2V). I noticed there is 3,2V instead of 3,3V but I think that it doesn't matter.
СообщениеДобавлено: 20 июн 2019, 15:32
Hi, again.
aleksros писал(а):
aleksros
, I didn't see your picture that is why I don't check it like you wish. Now I Checked it there are 3,3V everywhere.
I have ran this card on my second PC where I have graphics on my motherboard. What is more the "Device Manager" see this card. Unfortunately, there is an error 43 .
Sprawdziłem także tę kartę za pomocą GPU-Z i jest wersja BIOS-u - niezdefiniowana i pamięć wynosi 0 GB. Załączam ekran drukowania GPU-z.
I tired to use nvflash to update bios but I have errors.
СообщениеДобавлено: 20 июн 2019, 15:49
Hi. Shorts are not present, but what about resistanses?
СообщениеДобавлено: 20 июн 2019, 19:06
BrasilBack писал(а):
I
Resistances look ok.
This card has dual bios. I have CH341A programmer. I have downloaded bios from this site: https://www.techpowerup.com/vgabios/178 ... 096-150701 and write it to both chips.
I havent got oryginal bios unfortunately. Is this procedure ok or I have to do something else?
Maybe have you got another bioses for 4GB card?
Posted after 3 hours 53 minutes 30 seconds:
Hi again,
I don't know how but I made a mistake. There are missing 3,3V on the 6th leg of bios chip. It is SCLK (serial clock input).
I have tried to add 3.3v from external source and the PC starts but without screen.
Can it be a GPU faulty?
Posted after 1 hour 12 minutes 25 seconds:
Update: I took off GPU, and the power is back. However I'm still not sure is it GPU faulty. Is someone can confirm?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 3521 (LA-9104P) Computer Start on 0.49A but no picture
в форуме Dell
Dimension
3800
14 май 2015, 13:17
Dimension Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. обрыв температурного датчика видеокарты gigabyte gtx 960 2 gb
toster80
1645
21 авг 2019, 08:52
toster80 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gtx 960 gigabyte (опознать элемент)
gladja
30 авг 2019, 13:03
meohaimat2021 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte GTX 960 4GB "Please power down and connect...."
potas
30 июн 2020, 18:43
potas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte GTX 960 2Gb GV-N960WF2OC-2GD REV:1.0 кз по фазе питания из-за AZL
КомпБит
19 авг 2020, 16:54
КомпБит Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 30
