aleksros писал(а):
replace the thermal grease and check the efficiency of the radiator.
I replace another radiator but not success, sir!!!
Posted after 2 hours 58 minutes 34 seconds:aleksros писал(а):
very high temperature GPU, and therefore resets the frequency. replace the thermal grease and check the efficiency of the radiator.
I change to 4 radiator, it work normal. Thank so much ^^
