MSI GTX 970 - memory swap to another company https://vlab.su/viewtopic.php?f=48&t=91941 |
Micchaleq [ 06 июл 2019, 09:58 ] | |
Заголовок сообщения: | MSI GTX 970 - memory swap to another company |
Hi all, I have a question about GTX 970 from MSI company and maybe another 970 series card. I have an old PCB without memory and now I would like to place them there. The problem is that I don't know which company was there. I have Hynix memory now. I heard that when the memory are swapped there are additional resistors have to be placed or swap some of them (something like that). That is why I would like to ask you is it true? Do I have to change something? Maybe I can use Elpida, Samsung or Hynix interchangeably? That mean it doesn't matter about company of memory, GPU or BIOS detects it automatically. The memory which I saw on the MSI 970 is: ELPIDA: W4032BABG-70-F SAMSUNG: K4G41325FC-HC28 The SKhynix which I have is: H5GC4H24AJA T2C |
aleksros [ 06 июл 2019, 11:24 ] | |
Заголовок сообщения: | Re: MSI GTX 970 - memory swap to another company |
write the serial number of your videocard, I will tell you what kind of memory it was installed from the factory. |
Micchaleq [ 08 июл 2019, 11:53 ] | |
aleksros писал(а): write the serial number of your videocard, I will tell you what kind of memory it was installed from the factory. Hi, The serial number is: 602 V316 09SB1410039222 |
aleksros [ 08 июл 2019, 12:22 ] | |
HYNIX/H5GQ4H24MFR-R2C this memory from factory |
speedtm [ 08 июл 2019, 14:14 ] | |
aleksros писал(а): HYNIX/H5GQ4H24MFR-R2C this memory from factory Простите за не скромный вопрос а как вы узнали какая память стоит с завода?) |
Micchaleq [ 08 июл 2019, 14:57 ] | |
aleksros писал(а): HYNIX/H5GQ4H24MFR-R2C this memory from factory Thank you very much. I will order this model. On the other hands. Is this memory can be replaced for Samsung or ELPIDA? As in the first post is there special resistor which define which memory is used? |
aleksros [ 08 июл 2019, 15:40 ] | |
speedtm писал(а): Простите за не скромный вопрос а как вы узнали какая память стоит с завода?) msi сказал )) |
semlabin [ 08 июл 2019, 20:40 ] | |
да резистор есть, по 5 ножке флешки биос, 20к самсунг, 15к хуникс, 10к элпида! |
Micchaleq [ 09 июл 2019, 00:50 ] | |
semlabin писал(а): да резистор есть, по 5 ножке флешки биос, 20к самсунг, 15к хуникс, 10к элпида! спасибо / Thank you |
den800 [ 30 сен 2021, 14:04 ] | |
Да резистор есть, по 5 ножке флешки биос, 20к самсунг, 15к хуникс, 10к элпида! Не могу найти этот резистор,поменял банки с хуникс на элпиду,но не разберусь чтоб отображалось правильно. Не подскажите номер резистора по схеме? |
