Please, help me, I'm following the instructions on how to create a boot from usb and extract the mods folder but still get an error or can't find the card or can't see the display, sometimes it's testing but doesn't have it As a result, please show me how to install and which hardware is compatible with mods & mats. I am using Giga H81M-DS2 motherboard to check the card
Robert2140
Заголовок сообщения: Re: Help Mods & Mats
Добавлено: 24 сен 2019, 11:05
Зарегистрирован: 05 ноя 2015, 23:56 Наличности на руках: 3.17 Сообщения: 160 Откуда: Нижний Тагил
insert the card into the motherboard and select image output via pci-e. even if there is no image on the video card. the test starts automatically, you need to wait 2 minutes. then go to the mods folder and you will see a report file. it will be the test results.
Сейчас этот форум просматривают: Koks_7 и гости: 16
