Текущее время: 02 июн 2024, 20:34
yukas
Заголовок сообщения: ищу прошивку EDFME firmware /NVME PS5013-E13 Добавлено: 31 окт 2023, 16:03 |
Сообщения: 8 Откуда: vrn
за П/Д/К ищу прошивку для nvme
v0.385a OS: 10.0 build 19044 Drive : 2(USB) Fw : EDFME0.0 HMB : 1640 - 279344 KB Size : 244198 MB [256.1 GB] LBA Size: 512 AdminCmd: 0x00 0x01 0x02 0x04 0x05 0x06 0x08 0x09 0x0A 0x0C 0x10 0x11 0x14 0x18 0x80 0x81 0x82 0x84 0xD0 0xD1 0xD2 0xE0 0xE1 0xE2 0xF4 I/O Cmd : 0x00 0x01 0x02 0x04 0x08 0x09 Firmware lock supported [02 01] [P001] [0100] Handshake error: 0 Drive unlocked [02 03] F/W : EDFME0.0 P/N : 511-220505155 Bank00: 0x9b,0xc4,0x28,0x49,0x20,0x0,0x0,0x0 - YMTC 3dv3-128L(x2-9060) TLC 16k 512Gb/CE 512Gb/die 4Plane/die Bank01: 0x9b,0xc4,0x28,0x49,0x20,0x0,0x0,0x0 - YMTC 3dv3-128L(x2-9060) TLC 16k 512Gb/CE 512Gb/die 4Plane/die Bank02: 0x9b,0xc4,0x28,0x49,0x20,0x0,0x0,0x0 - YMTC 3dv3-128L(x2-9060) TLC 16k 512Gb/CE 512Gb/die 4Plane/die Bank03: 0x9b,0xc4,0x28,0x49,0x20,0x0,0x0,0x0 - YMTC 3dv3-128L(x2-9060) TLC 16k 512Gb/CE 512Gb/die 4Plane/die Controller : PS5013-E13 CPU Clk : 667 Flash CE : 4 Flash Channel : 4 Interleave : 1 Flash CE Mask : [++++---- -------- -------- --------] Flash Clk,MT : 800 Die per CE : 1 Block per CE : 1980 Page per Block: 2304 Bit Per Cell : 3(TLC) PMIC Type : PS6103 PE Cycle Limit: 40000/3000 SLC cache : 0x600000/0x340000
ONFI : YMTC YMN09TC1W00C6C (2021-51) [A223] Page size : 18432 (16384+2048) Page/Block: 2304 Block/LUN : 1980 LUN/Chip : 1 Bit/Cell : 3 (TLC) Endurance : 3000 PlanAdrBit: 2 (4 plane)
Defects Early Read Prog Erase Bank00: 16 0 0 0 Bank01: 9 0 0 0 Bank02: 18 0 0 0 Bank03: 12 0 0 0 Total : 55 0 0 0
Defects Early Read Prog Erase Ce00Pl0: 5 0 0 0 Ce00Pl1: 3 0 0 0 Ce00Pl2: 4 0 0 0 Ce00Pl3: 4 0 0 0 Ce01Pl0: 3 0 0 0 Ce01Pl1: 1 0 0 0 Ce01Pl2: 2 0 0 0 Ce01Pl3: 3 0 0 0 Ce02Pl0: 5 0 0 0 Ce02Pl1: 6 0 0 0 Ce02Pl2: 3 0 0 0 Ce02Pl3: 4 0 0 0 Ce03Pl0: 1 0 0 0 Ce03Pl1: 2 0 0 0 Ce03Pl2: 6 0 0 0 Ce03Pl3: 3 0 0 0 Total : 55 0 0 0
Xabib2302
Заголовок сообщения: Re: ищу прошивку EDFME firmware /NVME PS5013-E13 Добавлено: 05 ноя 2023, 09:27 |
Зарегистрирован: 21 янв 2015, 21:29 Наличности на руках: 18.02
Сообщения: 23 Откуда: РБ Гомель
Попробуйте Вложение: firmware_ps5013.rar
yukas
Заголовок сообщения: Re: ищу прошивку EDFME firmware /NVME PS5013-E13 Добавлено: 10 ноя 2023, 18:44 |
Xabib2302 писал(а): irmware_ps5013.rar спасибо, но я ищу EDFME прошивки, как указано в теме. Ваш архив под старые версии - он не подходит для EDFME !!! Там масса нюансов. ps. Если у кого есть - куплю за дорого!
